Change loginscreen background in Catalina
  • March 13, 2020
  • 13 views
In my organization (Higher Ed) we do a bit of school branding on all of our systems. One being we set a custom background image at the login screens in our labs and classrooms. Did this in Mojave by making our image an heic extension and naming it Mojave then placing it in /Library/Desktop Pictures.
In Catalina that directory moved to /System/Library/Desktop Pictures which you can not write to. I did find a way to do it via disabling System Integrity Protection SIP, making the change then re-enabling it. That is a lot to do on a few hundred machines. Does anybody have a better method to change that image or should I just forget about it?
Thanks in advance.
Best answer by Hugonaut
Not possible w/o disabling SIP. (As far as I know. If someone has a solution let me know!!!)
BUT, you can use NoMad Login & Configure the login windows wallpaper for your organization & it works on Catalina.
Hugonaut
Forum|alt.badge.img+15
  • March 13, 2020
  • August 18, 2021
If NoMad can do it, then we should be able to to do it on DEP devices too I would imagine. NoMad doesn't require SIP to be disabled, right? It seems like this must be some form of custom setting...
