Google Secure LDAP / Jamf Pro
  • September 23, 2019
  • 0 replies
  • 11 views
Has anyone gotten this working to the point where they can authenticate to the JAMF web app?
I have this working fine for user/group lookups but not for authentication. All attributes are returned correctly I just cannot use a Google LDAP user to login to JAMF. According to JAMF, Google, and the JNUC Session video it should just work. Anyone here run into this?
Currently running JAMF 10.14 on prem on Ubuntu with Stunnel running on the same server.
Messages in the Google console claim invalid credentials when I try to authenticate. I know the password is correct but I suspect they really mean that the LDAP user does not have sufficient privileges to browse the directory and validate their own password. There doesn't seem to be anyway to change them though.
