Configuring "new" Connection Types in the VPN macOS Configuration Profile
  • March 26, 2020
  • 8 replies
  • 113 views
ega
In the latest versions of Jamf Pro I am seeing several new Connection Types available in the VPN option of macOS Configuration Profiles (and mobile too).
I am interested in using the Connection Type of /Cisco AnyConnect. I can't find any documentation on what should go in the fields or how it relates to the Cisco AnyConnect Secure Mobility Client (if it does at all). Is anyone using this or knows of any documentation?
For the record the "new" types are
Cisco Legacy AnyConnect
Cisco AnyConnect
Juniper SSL
F5 SSL
SonicWaALL Mobile Connect
Aruba VIA
Check Point Mobile VPN
Custom SSL
  • April 13, 2020
Id like to use checkpoint vpn with this
  • April 15, 2020
I’m interested in Check Point configuration as well. And documentation on this?
Forum|alt.badge.img+15
  • April 15, 2020
Following this as well. We use Cisco AnyConnect and I saw this same thing and wondered the same question - what needs to go in the fields. I assume the server field is the vpn address you are connecting to. However, I noticed that it's looking for user authentication and we use machine cert authentication. I didn't see an option listed in there for it to authenticate via machine cert. I was hoping that this would replace the xml file we are currently using. Hopefully someone on JamfNation is using this and can provide some insight.
Anyone was able to use it with Checkpoint?
  • August 15, 2020
I am interested in this, I will be following this thread, we use Junos Pulse secure.
MikaelDez
  • July 20, 2022
Also interested in this 2 years later. If anyone has been able to configure checkpoint with Jamf to preload site information I'd love to hear how it was done!
  • August 25, 2022
wow really!!! nothing
  • September 13, 2023
I am also interested if there is documentation on using CheckPoint with this. Has anyone got success with this?
