How to offline add a domain user to a mac
  • March 26, 2020
  • 53 replies
  • 535 views
I'm working through some remote support issues for macs, and stuck on this one. Mac is remote, and has to use a VPN to connect to the domain. Normally, after the machine joins the domain (no problem - I connect with the VPN and join) I log off as the local user then login as the domain user. Then I create a mobile account and all's well.
However, because the connection to the VPN drops once the local user is logged out, you can not login as a domain user because it can't look it up on the domain.
With Windows, we get around this issue by using "Change User" which doesn't actually log off the local user and doesn't break the VPN connection to the domain. I don't see how to accomplish this on a Mac, and because we support remote users with Macs, we need to be able to set them up on the domain.
One thing I tried was to create a local account using the domain ID/password, then login with it, connect to the VPN/domain, then tick "mobile account" but for that type of account it does not give a mobile option.
I also tried turning on Fast Switching (users) and selecting 'other user' and trying to log in then, but it won't allow it - apparently that breaks the VPN connection too (or perhaps Fast Switching requires an established account).
Thoughts? We just us OS Catalina
  • March 26, 2020
Assuming the device has a valid connection while on VPN. Have the user open a terminal prompt and use the login command. It will prompt for user name and password. Once that login has been confirmed. Use this command to create a mobile account
sudo /System/Library/CoreServices/ManagedClient.app/Contents/Resources/createmobileaccount -n username
  • March 26, 2020
When I try to put in the username it tells me its incorrect. I am already on the Domain and connected to a vpn on the local admin account. Any Ideas? I am trying to login as as a new domain user.
  • March 27, 2020
Despite my trying in a ton of different ways I was never able to script this. I had to type it in to terminal on the computer.
sudo /System/Library/CoreServices/ManagedClient.app/Contents/Resources/createmobileaccount -a $adminUsername -U $adminPassword -n $USERNAME
That will put the user account on the computer
dscacheutil -q user -a name $USERNAME
that will cache the users password so you can log in with them.
  • March 27, 2020
When you log into the system while on VPN in the terminal window use the command "id $USERNAME" if the command comes back no such user , then the device has lost its domain join. Run your bind policy again on the device then try to login.
  • March 27, 2020
@strayer unfortunately the first line keeps asking for the user's password which I am positive is correct. It returns with "Sorry please try again"
@rwinfie I ran that command and its seems to come back with a bunch of information such as Admin information Staff information etc. I tried a user name that I know is not on our domain but it returned with the same information as above.
  • March 27, 2020
@tjosey The password it's asking for is the admin users password because it is a sudo command.
The process I use never requires you to enter the user account you are adding's password into terminal
EDIT: You also may want to rebind the computer to the domain if it's having trouble finding the user.
  • March 27, 2020
@strayer For example the I tried adding myself as Tjosey. I have made a test account on the domain I am typing in the following on Terminal:
sudo /System/Library/CoreServices/ManagedClient.app/Contents/Resources/createmobileaccount -a $Administartor(Local Admin Account) -U $(Password for local administrator) -n $tjosey
It then ask me for a password in which I put in the local admin account and returns with the following error
* error: "-n username" is a required argument
Any ideas on what I am doing wrong. Really appreciate the help on this.
Also rejoined bind it to the domain
  • March 27, 2020
@strayer remove the $
  • March 27, 2020
@rwinfie i removed the entire command and got the error "
*user name "tjosey" was not found: 0 ((null))
the VPN connection I have is stable and I am able to access different resources not normally available outside the network. When I enet the username do I have to put in the domain as well?
  • March 27, 2020
Ok , lets try this , please send the output of the command id tjosey
  • March 27, 2020
@tjosey the $ was there to indicate a variable and should not be included. sorry about that.
Not sure what your vpn setup is like, but our company has a limited always on VPN and a full access VPN that requires authentication. For us this only works on the Full access vpn because the limited VPN does not have access to AD, only a small set of very commonly used internal resources.
Before I put in the answer I ran these commands on my computer and it was successful in putting the account on my machine. I agree with @rwinfie to try id tjosey and maybe unbind and rebind the computer before proceeding further.
I also tried on limited VPN first and failed then i switched to full VPN then it gave me an error on the full VPN as well. I started a new terminal session and then it succeeded. So maybe after you verify your VPN connection and AD bind is good quit and relaunch terminal.
  • March 28, 2020
@strayer I think we made some progress. I am able to Id Tjosey. Pulls the domain that I am a part of as well. Did a test for another Domain user with the same results. When I tried a none domain user its says "user not found" so thats progress! However, when I enetr the below command it says the * admin authentication failed. Any Idea? The command I typed is below
sudo /System/Library/CoreServices/ManagedClient.app/Contents/Resources/createmobileaccount -a Administartor(Local Admin Account) -U (Password for local administrator) -n tjosey
Can you confirm which password its asking for when I run this command? Right now I am putting the local admin password which is returning the error.
  • March 30, 2020
@tjosey That is the admin password you should be entering. Doing some testing on my machine I get the "Admin authentication failed" error when the admin password is not entered correctly.
if the user is not an admin or does not exist it gives an error.
  • March 30, 2020
@strayer Is it the local admin to the machine or a domain admin that I need to log in with?
  • March 30, 2020
@tjosey it is a local admin on the machine.
  • March 30, 2020
@strayer what credentials am I using for -a $adminUsername -U $adminPassword? Is it also the local admin or a varified domain user?
  • March 30, 2020
@tjosey That is the login i was referring to and is also a local admin on the machine. When we do a remote setup we have a local non-domain admin. We are logged into that user and enter the command using that -a localadminusername -U localadminpassword -n accountweareadding
if the computer is already bound to AD you never need domain admin credentials to do any of this.
Thanks everyone for this interesting thread! I always wanted to have the option to add a domain user offline but never found a working solution.
I just tried the following steps:
- Configured and tested VPN connection -> OK
- Manually bound device to our domain -> OK
- Run id myDomainUser and got a bunch of data as result -> OK
- Added my domain user as a mobile user account with: sudo /System/Library/CoreServices/ManagedClient.app/Contents/Resources/createmobileaccount -a myLocalAdminAccount -U 'myLocalAdminPassword' -n myDomainUser -> OK (btw, the SINGLE quotes are important, when the password contains special characters!)
- Cached local password with: dscacheutil -q user -a name myDomainUser -> OK (at least no error)
I see the new domain user in Users & Groups as "mobile". But when I want to login with this account (offline of course), nothing happens. The new domain user will be shown on the login screen and I can enter the password, but then nothing happens and after this I can't re-enter the password anymore. (The password does not shake, so it's not denied, it just does not work.)
So, it seems, I only have to fix this last step. But without this I can't use this scenario, as I need to login with a cached password.
I'm using 10.15.3 on my test device. Does the dscacheutil really fetch the password from the domain and save it in the local cache? I was never prompted for the domain user password.
P.S.: @strayer How did you color format some of your commands??
  • March 31, 2020
@hansjoerg.watzl Ran across the exact same issue but I managed to get around it Yesterday! Will post a detailed thread later. However, after you run the command "dscacheutil -q user -a name myDomainUser" switch the user in terminal using the SU myDomainUser command. This will prompt you to put the password in for that user. Once that is done you should be able to log off the current account and login as that user!
Also, Thank you so much for mentioning quotes are needed for passwords with special characters! It was driving me crazy why my original local admin password was failing so I created another local test account with a simple password to get around it!. I'll try it with my original local admin password with the quotes you mentioned.
Wow! Thanks for this! Now it works....the first time I could configure a BYOD Mac to a domain bound Mac with domain user added from outside the corporate network (only VPN).
I'm wondering, if the dscacheutil command is really needed or if just the su command alone did the trick....
  • March 31, 2020
@hansjoerg.watzl @tjosey Options other than su you can also do login and login as that username and password. or do /usr/bin/dscl /Search -authonly adUsername adPassword
I have done this with just the dscacheutil command and the advantage of that is that you don't need to know the users password. Which may not be an issue for you guys, but is an important part of the process that I am using it for.
@strayer But when you just use dscacheutil, how is then the user be able to login (offline)? Or do you provide him the instructions, how to do the login command in terminal?
I still don't know, what dscacheutil really does? Regarding the man page, dscacheutil -q user -a name jdoe just does a lookup. Does this lookup fetch and store the password locally or just show the user? Or does it prepare the cache, so AFTER the next authentication the password is cached locally?
btw dscacheutil -cachedump brings me only Unable to get details from the cache node
(Would still be thankful if you could tell me how you format the color text in your messages ;-) )
  • March 31, 2020
I format color in my messages by using backticks `
We put a Setup account on the computer, do the dscacheutil instruction and we have fast user switching enabled with a config profile and the user does fast user switching over to their user account.
this used to be an emergency remote setup measure, but now with the current pandemic and over 90% of my company working from home we are having to use this method more.
  • April 1, 2020
@tjosey @hansjoerg.watzl I put together a script that got this working in Self Service.
our first test with a user we are shipping a computer to is tomorrow, but it's been working over VPN on my computer in repeated tests.
It prompts the user for the username and password of the account to be added to the computer.
the local admin account username and password need to be passed to the script as variables 4 and 5
it also adds the user to Filevault using the same admin credentials, but you can delete that part from the end if you don't need that.
We also use fast user switching so I kill the menu bar process after the user account is created so the User gets added to Fast User switching.
I referenced https://github.com/rtrouton/rtrouton_scripts/blob/master/rtrouton_scripts/migrate_local_user_to_AD_domain/MigrateLocalUserToADDomainAcct.command
for some of the commands.
#!bin/bash
adminUser="$4"
adminPass="$5"
osvers=$(sw_vers -productVersion | awk -F. '{print $2}')
check4AD=`/usr/bin/dscl localhost -list . | grep "Active Directory"`
## verify that adminuser and pass variables are both passed to the user
if [[ -z "$adminUser" ]] || [[ -z "$adminPass" ]] ; then
    dialog="either Admin User or Password is missing"
    echo "$dialog"
    cmd="Tell app "System Events" to display dialog "$dialog""
    /usr/bin/osascript -e "$cmd"
    exit 1
## check the admin password
adminCheck=$(/usr/bin/dscl /Local/Default -authonly "$adminUser" "$adminPass")
if [[ -z "$adminCheck" ]] ; then
    echo "Admin password is verified"
    echo "Admin Password not working"
    exit 1
# If the machine is not bound to AD, then there's no purpose going any further.
if [ "${check4AD}" != "Active Directory" ]; then
    dialog="This machine is not bound to Active Directory.
Please bind to AD first. "
    echo "$dialog"
    exit 1
## Prompt for Username
userToAdd=$(/usr/bin/osascript<<END
activate
set the answer to text returned of (display dialog "Enter the username to add to this computer" default answer "" buttons {"Continue"} default button 1)
end tell
END
## Prompt for Password
userPass=$(/usr/bin/osascript<<END
activate
set the answer to text returned of (display dialog "Please enter the user's account Password:" default answer "" with hidden answer buttons {"Continue"} default button 1)
end tell
END
loopCount=0
while [ "$loopCount" -lt 3 ]; do
    # Refresh Directory Services
    if [[ ${osvers} -ge 7 ]]; then
        /usr/bin/killall opendirectoryd
        /usr/bin/killall DirectoryService
    sleep 15
    ## try to auth the user in advance. this seems to increase the success of the ID command.
    /usr/bin/dscl /Search -authonly "$userToAdd" "$userPass"
    adCheck=`id $userToAdd`
    echo "AD Check is: $adCheck"
    if [[ -z "$adCheck" ]] ; then
        ((loopCount++))
        echo "AD Check successful"
        break
done
    dialog="AD User Not found. Verify Good Full VPN connection and Rebind to Domain if needed."
    echo "$dialog"
    exit 1
sleep 2
## hit AD create the user
/System/Library/CoreServices/ManagedClient.app/Contents/Resources/createmobileaccount -a "$adminUser" -U "$adminPass" -n "$userToAdd"
sleep 2
## check to see if the user account was added
userCheck=$(dscl . list /Users | grep "$userToAdd")
if [[ -z "$userCheck" ]] ; then
    dialog="AD User failed to add."
    echo "dialog"
    exit 1
## this should query AD to cache the user including the password
dscacheutil -q user -a name "$userToAdd"
## this will auth the user to AD and should also cache their password locally
## this kills the menubar so that the fast user switching list refreshes
killall -KILL SystemUIServer
## NOW that we've verified the user exists let's add the user to FileVault
# create the plist file:
echo '<?xml version="1.0" encoding="UTF-8"?>
<plist version="1.0">
<dict>
<key>Username</key>
<string>'$adminUser'</string>
<key>Password</key>
<string>'$adminPass'</string>
<key>AdditionalUsers</key>
<array>
    <dict>
        <key>Username</key>
        <string>'$userToAdd'</string>
        <key>Password</key>
        <string>'$userPass'</string>
    </dict>
</array>
</dict>
</plist>' > /tmp/fvenable.plist  ### you can place this file anywhere just adjust the fdesetup line below
# now enable FileVault
fdesetup add -i < /tmp/fvenable.plist
rm -r /tmp/fvenable.plist
fdeList=`fdesetup list | grep $userToAdd`
if [[ "$fdeList" == *"$userToAdd"* ]] ; then
    dialog="$userToAdd account created, and added to Filevault Successfully"
    echo "$dialog"
    dialog="$userToAdd account created, please run the 'Update Filevault Password' policy in Self Service"
    echo "$dialog"
markopolo
  • April 3, 2020
@strayer Thank you for posting your script! I'm currently getting "either Admin User or Password is missing" even though I've plugged them in as such:
adminUser="localadmin"
adminPass="<password>"
Any ideas?
Update: Changed double quotes to single and now it's passing creds. However, now I'm getting "AD User Not found. Verify Good Full VPN connection and Rebind to Domain if needed". I'm fairly confident in both VPN and AD binding, though. Anything else I should check?
Update2: Removed the "adCheck" portion of the script and it appears to be working now! W00t!! You rock dude!!!
