Automate Mobile Account into Admin
  • April 2, 2020
  • 5 replies
  • 68 views
Hi All
Probably a question asked in many different ways.
All the Macs in our environment are bound to AD & logged in as Mobile Accounts.
Is there a script without logging in as admins to make that that end user as an admin?
If so any solutions would be great.
Thanks
  • April 2, 2020
Hi @k84,
PSA: Before you start, please be absolutely certain you require users to have Admin access in your environment. You can run the risk of malware being system wide instead of contained to the User's account. You can also run the risk of User's removing Jamf.
There are a lot of methods of giving users admin level access for certain preferences. Check out this discussion of allowing user's access to printers and WIFI control.
Anyway, @rtrouton has a method for manually migrating the User's account from Mobile Accounts to Local (with an option to set it as Admin).
I also had a pretty high success rate with demobilizing automatically using @patgmac 's script, but it is no longer available on Github:
#!/usr/bin/env bash
# Modified 2019-04-08
VERSION=1.0
#   Original source is from MigrateUserHomeToDomainAcct.sh
#   Written by Patrick Gallagher - https://twitter.com/patgmac
#   Guidance and inspiration from Lisa Davies:
#   http://lisacherie.com/?p=239
#   Originally modified by: Rich Trouton
#   Modified by Matt Wilson
#   NAME
#       demobilize-automatically.sh -- Automatically remove a Mac from AD and
#       migrate all mobile user accounts to local user accounts.
#   DESCRIPTION
#       Automatically migrates all Active Directory mobile accounts to local
#       accounts on a given Mac by using the following process:
#       1. Detect if the Mac is bound to AD and automatically remove the Mac if
#          the REMOVE_FROM_AD global variable is set to "YES".
#          This can also be specified using the Jamf built-in variable $4.
#       2. Detect all accounts on the Mac with a UID over 1000. Mobile accounts
#          will typically have a UID well over 1000.
#       3. Remove the following attributes from each account. These attributes
#          identify the user account as a Mobile account.
#               cached_groups
#               cached_auth_policy
#               CopyTimestamp - This attribute is used by the OS to determine
#                               if the account is a mobile account
#               SMBPrimaryGroupSID
#               OriginalAuthenticationAuthority
#               OriginalNodeName
#               SMBSID
#               SMBScriptPath
#               SMBPasswordLastSet
#               SMBGroupRID
#               PrimaryNTDomain
#               AppleMetaRecordName
#               MCXSettings
#               MCXFlags
#       4. Modify the existing AuthenticationAuthority attribute by removing the
#          Kerberos and LocalCachedUser user values.
#       5. Restart the directory services process.
#       6. Check to see if the conversion process succeeded by checking the
#          OriginalNodeName attribute for the value "Active Directory". If the
#          conversion is not successful the incident will be logged.
#       7. Upon successful conversion update the permissions on the account's
#          home folder.
#            - For MacOS Mojave 10.14 make sure to either have a PPPC profile
#              uploaded to your MDM environment that grants the shell access to
#              the File system.
#       8. Set the ADMIN_RIGHTS global variable to define whether or not admin
#          rights should be give to the local account.
#          This can also be specified with the Jamf built-in variable $5.
# REMOVE THE MAC FROM ACTIVE DIRECTORY (YES/NO)
  REMOVE_FROM_AD="YES"
# MAKE THE USER ADMIN (YES/NO)
  ADMIN_RIGHTS="NO"
# Global Variable declarations
# CLEAR_BIN="/usr/bin/clear"
DSCL_BIN="/usr/bin/dscl"
FULL_SCRIPT_NAME=$(/usr/bin/basename "$0")
HERE=$(dirname "${PWD}/${FULL_SCRIPT_NAME}")
SHOW_VERSION="$FULL_SCRIPT_NAME Version $VERSION"
OS_VERSION=$(sw_vers -productVersion | awk -F. '{print $2}')
# Check the Jamf built-ins to see if they have been set.
if [[ $4 != "" ]]; then REMOVE_FROM_AD="$4"; fi
if [[ $5 != "" ]]; then ADMIN_RIGHTS="$4"; fi
function run_as_root()
    # Pass in the full path to the executable as $1
    # Pass in the name of the script as $2
    if [[ $(/usr/bin/id -u) -ne 0 ]] ; then
        # If not running the script as root user.
        /bin/echo
        /bin/echo "***  This application must be run as root. Please authenticate below.  ***"
        /bin/echo
        sudo "${1}/${2}" && exit 0
function remove_from_ad() {
    # This function force-unbinds the Mac from the existing Active Directory
    # domain and updates the search path settings to remove references to
    # Active Directory
    local _SEARCH_PATH
    _SEARCH_PATH=$("$DSCL_BIN" /Search -read . CSPSearchPath |
        /usr/bin/grep Active Directory |
        /usr/bin/sed 's/^ //')
    # Force unbind from Active Directory
    /usr/sbin/dsconfigad -remove -force -u none -p none
    # Deletes the Active Directory domain from the custom /Search
    # and /Search/Contacts paths
    "$DSCL_BIN" /Search/Contacts -delete . CSPSearchPath "$_SEARCH_PATH"
    "$DSCL_BIN" /Search -delete . CSPSearchPath "$_SEARCH_PATH"
    # Changes the /Search and /Search/Contacts path type from Custom to
    # Automatic
    "$DSCL_BIN" /Search -change .
        SearchPolicy dsAttrTypeStandard:CSPSearchPath dsAttrTypeStandard:NSPSearchPath
    "$DSCL_BIN" /Search/Contacts -change .
function check_ad_binding_status() {
    # Check for AD binding and unbind automatically if bound.
    # AD status
    local _AD_STATUS
    _AD_STATUS=$("$DSCL_BIN" localhost -list . |
        /usr/bin/grep "Active Directory" 2> /dev/null)
    if [[ $_AD_STATUS == "Active Directory" ]]; then
        # If the Mac is bound to AD
        echo ""
        echo "This machine is bound to Active Directory."
        echo "Remove Mac from AD set to: ${REMOVE_FROM_AD}"
        if [[ $REMOVE_FROM_AD == "YES" ]]; then
            echo "Forcing the unbind of this Mac from AD ..."
            /bin/sleep 1
            remove_from_ad
            echo "AD binding has been removed."
            echo "Mac will remain bound to AD ..."
        echo ""
        echo "This Mac is not bound to an AD domain."
        echo "Checking users ..."
        echo ""
function get_all_mobile_users() {
    # Get all mobile users with a UID greater than 1000
    LIST_USERS=$("$DSCL_BIN" . list /Users UniqueID |
        /usr/bin/awk '$2 > 1000 {print $1}' |
        /usr/bin/sed -e 's/^[ 	]*//')
    echo "Looking for Mobile user accounts ..."
    if [[ ${LIST_USERS} == "" ]]; then
        # If no users with UID over 1000 are returned, Quit.
        echo "No AD mobile user accounts found."
        echo "Nothing to do ..."
        echo "Exiting ..."
        echo ""
        /bin/sleep 1
    for user in ${LIST_USERS}; do
        echo "Found: $user"
    done
function check_user_account_type() {
    # Determine the user account type
    # Takes in the $netname as $1
    # Takes in the attempt attribute as $2
    #   1 = first account check before account conversion
    #   2 = second account check after account conversion
    local _ACCOUNT_TYPE
    local _MOBILE_USER_CHECK
    local _ACCOUNT_CHECK=$2
    echo "Checking user account type ... $_ACCOUNT_CHECK"
    # Grab the user account type
    _ACCOUNT_TYPE=$("$DSCL_BIN" .
        -read /Users/"$1" AuthenticationAuthority |
        /usr/bin/head -2 |
        /usr/bin/awk -F'/' '{print $2}' |
        /usr/bin/tr -d '
    if [[ $_ACCOUNT_CHECK -eq 1 ]]; then
        # Check the user account type before attemtpting to convert the account.
        _MOBILE_USER_CHECK=$("$DSCL_BIN" .
            /usr/bin/head -2 |
            /usr/bin/awk -F'/' '{print $1}' |
            /usr/bin/tr -d '
            /usr/bin/sed 's/^[^:]*: //' |
            /usr/bin/sed s/;/""/g)
        if [[ $_ACCOUNT_TYPE = "Active Directory" ]] || [[ $_MOBILE_USER_CHECK = "LocalCachedUser" ]]; then
            echo "$1 has an AD mobile account."
            echo "Converting to a local account with the same username and UID."
            echo "The $1 account is not a AD mobile account."
            echo ""
            break
    if [[ $_ACCOUNT_CHECK -eq 2 ]]; then
        # Check the user account type after the convertion to ensure that
        # everything converted properly.
        if [[ "$_ACCOUNT_TYPE" = "Active Directory" ]]; then
            # If the account type is still listed as Active Directory
            /bin/echo "Something went wrong with the conversion process."
            /bin/echo "The $netname account is still an AD mobile account."
            /bin/echo ""
            exit 1
            /usr/bin/printf "Conversion process was successful.
The $netname account is now a local account.
function remove_ad_account_attributes() {
    # Remove the account attributes that identify the user account as an Active
    # Directory mobile account
    # Pass in $netname as $1
    echo "Removing attributes that identity user as a mobile account ..."
    # Add or remove mobile account attributes to the array as needed
    MOBILE_ATTR=(
        cached_groups
        cached_auth_policy
        CopyTimestamp
        AltSecurityIdentities
        SMBPrimaryGroupSID
        OriginalNodeName
        SMBSID
        SMBScriptPath
        SMBPasswordLastSet
        SMBGroupRID
        PrimaryNTDomain
        AppleMetaRecordName
        PrimaryNTDomain
        MCXSettings
        MCXFlags
    for attr in "${MOBILE_ATTR[@]}"; do
        "$DSCL_BIN" . -delete /Users/$1 ${attr}
        local RESULT=$?
        if [[ $RESULT -ne 0 ]]; then
            # Failed to remove attribute
            echo "Failed to remove account attribute ${attr}"
            echo "Removed: ${attr}"
    done
function password_migration() {
    # macOS 10.14.4 will remove the the actual ShadowHashData key immediately
    # if the AuthenticationAuthority array value which references the ShadowHash
    # is removed from the AuthenticationAuthority array. To address this, the
    # existing AuthenticationAuthority array will be modified to remove the
    # Takes in the "$netname" as $1
    /bin/echo "Migrating user password ..."
    /bin/echo "Modifying AuthenticationAuthority key attribute ..."
    AUTHENTICATION_AUTHORITY=$(/usr/bin/dscl -plist . -read
        /Users/$1 AuthenticationAuthority)
    KERBEROS_V5=$(echo "${AUTHENTICATION_AUTHORITY}" |
        xmllint --xpath
        'string(//string[contains(text(),"Kerberosv5")])' -)
    LOCAL_CACHED_USER=$(echo "${AUTHENTICATION_AUTHORITY}" |
        xmllint --xpath
        'string(//string[contains(text(),"LocalCachedUser")])' -)
    if [[ ! -z "${KERBEROS_V5}" ]]; then
        # Remove Kerberosv5
        /bin/echo "Removing Kerverosv5 key value ..."
            -delete /Users/$1 AuthenticationAuthority "${KERBEROS_V5}"
    if [[ ! -z "${LOCAL_CACHED_USER}" ]]; then
        # LocalCachedUser
        /bin/echo "Removing the LocalCachedUser key value ..."
            -delete /Users/$1 AuthenticationAuthority "${LOCAL_CACHED_USER}"
function restart_directory_services() {
    # Refresh Directory Services
    # $1 = OS_VERSION
    echo "Restarting directory services ..."
    if [[ $1 -ge 7 ]]; then
        /usr/bin/killall opendirectoryd
        /usr/bin/killall DirectoryService
    # Allow time for things to settle
    echo "Sleeping 20 seconds to allow things to settle down ..."
    /bin/sleep 20
function modify_user_stuff() {
    # Modify stuff owned by user being migrated
    # Change home directory permissions
    # Add the user to the local staff group
    # With MacOS Mojave (10.14) be sure to either grant disk access to the
    # Terminal or deploy a PPPC profile from your MDM while running this
    # function to change ownership of the user's home directory. Otherwise,
    # MacOS will prevent the user's Library directory permissions from being
    # altered.
    # $1 = netname
    local _HOME_DIR
    # Grab the home directory
    _HOME_DIR=$("$DSCL_BIN" . -read /Users/"$1" NFSHomeDirectory |
        /usr/bin/awk '{print $2}')
    if [[ "$_HOME_DIR" != "" ]]; then
        # Change ownership of home directory to local user
        /bin/echo "Home directory location: $_HOME_DIR"
        /bin/echo "Updating home folder permissions for the $1 account"
        /usr/sbin/chown -R "$1" "$_HOME_DIR"
    # Add user to the staff group on the Mac
    echo "Adding $1 to the staff group on this Mac."
    echo ""
    /usr/sbin/dseditgroup -o edit -a "$1" -t user staff
    # Show user and gorup information for the user being migrated
    echo  "User and group information for the $1 account"
    /usr/bin/id $1
function make_user_admin() {
    # Make the migrated user a local admin
    # $1 = $netname
    # Prompt to see if the local account should be give admin rights.
    echo ""
    echo "Checking to see if user should be a local admin ..."
    echo "Admin Rights set to: ${ADMIN_RIGHTS}"
    if [[ $ADMIN_RIGHTS == "YES" ]]; then
        # If the amdin rights global has been set to "YES".
        /usr/sbin/dseditgroup -o edit -a "$1" -t user admin
        echo "Admin rights given to this account"
        echo "No admin rights given"
################################ MAIN FUNCTION ################################
function main () {
    # Main function
    # ${CLEAR_BIN}
    echo ""
    /bin/echo "********* Running $SHOW_VERSION *********"
    run_as_root "${HERE}" "${FULL_SCRIPT_NAME}"
    for netname in ${LIST_USERS}; do
        echo "Processing user: $netname"
        /bin/sleep 1
        check_user_account_type "${netname}" "1"
        remove_ad_account_attributes "${netname}"
        password_migration "${netname}"
        restart_directory_services "${OS_VERSION}"
        check_user_account_type "${netname}" "2"
        modify_user_stuff "${netname}"
        make_user_admin "${netname}"
    done
# Call main function
main
# Exit gracefully
  • April 2, 2020
Hi @shaquir
Thanks for this, I fully understand what risks it brings bit the business unfortunately favours those who bring in the big $$$$.
So we want to keep them as mobile accounts but with admin privileges.
I'll have a further look at the script you posted on here.
  • April 2, 2020
Hi @k84 ,
Sorry I misinterpreted your question. The script from my earlier post will also unbind the user from the domain.
To keep them bound to your domain, you should test and try:
https://github.com/palantir/jamf-pro-scripts/blob/master/scripts/Convert%20Logged-In%20User%20to%20Standard.sh
  • December 11, 2020
@shaquir The script you posted, do you run this as a policy in Self Service?
daniel_ross
Forum|alt.badge.img+20
  • October 25, 2021
Has this been working for anyone using 11.6 or even 10.15.7?
