Additionally to our Cloud Distribution Point I wanted to add a File Share Distribution Point that can be used when users are in the office.
I can add the SMB Share manually in Finder without any issues (using both the write and read account created specifically for that) but when I try to replicate in JAMF Admin it always fails:
-- Replicating to distribution point smb://10.10.11.51/jamfshare 25.11.20 07:50 --
2020-11-25 07:50:30: Comparing files based on checksum
2020-11-25 07:50:30: Mounting smb://10.10.11.51/jamfshare...
2020-11-25 07:50:35: ERROR: The distribution point could not be mounted. The replication operation will stop
2020-11-25 07:50:35: Finished.
I have also tried with port 445 and tried several settings for the Workgroup or Domain setting (the two accounts are local accounts) but I don't seem to be able to connect using JAMF Admin.
Has anyone else experienced this? Am I missing something?
Many thanks for your feedbacks!
Hi @felfelit
Did you ever find the fix? We're having the same problem and have a support ticket with Jamf but no solution yet.
