How to prevent Content Caching
  • April 10, 2020
  • 48 views
macbrun
I am trying to prevent our users from turning on content caching, yet when I use either Restrictions or the Content Caching payload it still allows the user to enable Content Caching. I am able to set the cache size to 1 byte, which I guess effectively disables it, however I'd like them to be unable to even check the Content Caching box in the Sharing Prefs Pane. Any ideas?
Best answer by macbrun
So I tried using the Restrictions payload again and it's working now. Not sure why it was giving me trouble before. I may have had a conflict with another Configuration Profile with a Restrictions payload.
  • April 10, 2020
I used "Profile Creator" to restrict that setting and it works. I don't remember why I used PC over Jamf, probably because it was a year ago and Jamf probably didn't have that setting yet.
macbrun
  • April 10, 2020
