I am looking into doing remote OS upgrades. I have put Catalina as a Mac Store App into the JSS, which installs the stub installer fine but then it requires admin credentials to complete the install. Is there any workaround that I can use to trigger completion of the OS? Would it be possible to use the stub installer in a script?
