Nowaday Xcode 11.4.* deployment
  • April 21, 2020
  • 22 views
mhasman
Forum|alt.badge.img+22
Hello,
Please share your best experience with latest Xcode deployment.
Downloaded file comes as Xcode_11.4.1.xip. I can open it, put to Applications, but then Composer crashes as I drop-n-drop Xcode, and crashes again as trying to make .DMG or .pkg. Maybe too big, too heavy for Composer?
What workaround would you recommend? Maybe... package Xcode_11.4.1.xip itself, then unarchive it in to Applications and delete .xip? What would be the commands for that, please?
  • April 21, 2020
hope this helps.
https://www.jamf.com/jamf-nation/discussions/30690/deploying-xcode-in-2019
dmahase
  • October 1, 2020
I was receiving the same error. I updated composer to the latest version and was able to build in composer.
