Hi Jamf Nation,
I am following the two guides below to update my O365 apps using MAU.
https://docs.jamf.com/technical-papers/jamf-pro/microsoft-office/10.18.0/Update_Microsoft_Office.html
To the users who use MAU, did you use one plist for configuration and another one for the apps? I might try two plists; currently I'm running them all in one plist file.
However, the apps will not update unless they've been opened before. MAU will download and try to install the update, but it will always fail.
Has anyone encountered this? Any insight would be gladly appreciated.
