Okay so I had created an apple scrip app that would force the system to check with caster and push updated by running two commands "sudo jamf manage" and "sudo JAMF policy" everythign was working fine until i upgraded my JSS to 9.82 no i get an error *
error "sudo: jamf: command not found"
Can any one tell what i need to change to make it work again.
thanks.
