Can someone see any obvious reason my plist isn't trigger scripts correctly?
  • May 5, 2020
  • 47 views
I have this .plist called update.plist and I wan't it to trigger a shell script called weekly_update_trigger.sh every minute (changing to weekly after testing) and this is what the plist looks like:
<plist version="1.0">
<dict>
        <key>Label</key>
        <string>update</string>
        <key>ProgramArguments</key>
        <array>
                <string>sudo</string>
                <string>sh</string>
                <string>/Library/JamfScripts/weekly_update_trigger.sh</string>
        </array>
        <key>StartInterval</key>
        <integer>60</integer>
</dict>
</plist>
Is there something obvious that I'm missing or that I should be looking for? The script isn't triggering, however when i run the script locally, it works.
The script is as such
sudo /usr/local/bin/jamf policy -trigger weeklyupdate
DBrowning
  • May 5, 2020
Have you tried removing the <string>sudo</string> line from the plist and the sudo from your script?
Also what are the permissions on each file?
sdagley
  • May 5, 2020
Here are some handy resources when it comes to LaunchAgents and LaunchDaemons...
Pretty much everything you need to know about creating them: A launchd Tutorial
A great tool for creating, and troubleshooting, them: LaunchControl - The launchd GUI
Forum|alt.badge.img+20
  • May 5, 2020
Are you trying to run this as a LaunchAgent or LaunchDaemon? Since you need to run this as an administrator, you can remove the sudo part and just run this as a LaunchDaemon. Also make sure your plist has the proper permissions chown root:wheel /path/to/plist and chmod 644 /path/to/plist
