Anyone have a solution for automating outlook signatures? I'd love to be able to use a template with someone filling in first name last name, phone number, address, company logo, email etc.
i am also looking for it.
There are a couple of things which you will need to do when planning to setup user signatures. First, you need to work out what data you are going to put into your user signature and secondly, how your are going to read the data into the signature file. It seems simple at first but you need to plan for this to be as light touch as possible. I recommend setting the signatures up once and then letting the user changing them via self service, you don't want to working out if a users job title changed every day.
If you been able to get Jamf to read everything in from Active Directory then you can user the built in variables within Jamf to push things like email address, department name, building, job title and address. I have include a json profile as an example so you can see what variables you get setup locally from Jamf software.
Now, you use a script to create a html file of your signature with the variables from Jamf server and then tell Microsoft Outlook via AppleScript to delete all current signatures and load the new one which has just been created.
JSON variables Example
com.samplepayload
"title": "com.samplepayload",
"description": "Sample Payload",
"properties": {
"Room": {
"title": "Room",
"description": "$ROOM",
"property_order": 5,
"anyOf": [
"type": "null",
"title": "Not Configured"
"title": "Configured",
"type": "string"
"MAC Address": {
"title": "MAC Address",
"description": "$MACADDRESS",
"property_order": 10,
"anyOf": [
"type": "null",
"type": "string"
"Site Name": {
"title": "Site Name",
"description": "$SITENAME",
"property_order": 15,
"anyOf": [
"type": "null",
"type": "string"
"Position": {
"title": "Position",
"description": "$POSITION",
"property_order": 20,
"anyOf": [
"type": "null",
"type": "string"
"Computer Name": {
"title": "Computer Name",
"description": "$COMPUTERNAME",
"property_order": 25,
"anyOf": [
"type": "null",
"type": "string"
"UDID": {
"title": "UDID",
"description": "$UDID",
"property_order": 30,
"anyOf": [
"type": "null",
"type": "string"
"Phone Number": {
"title": "Phone Number",
"description": "$PHONE",
"property_order": 35,
"anyOf": [
"type": "null",
"type": "string"
"Extension Attribute ID Number": {
"title": "Extension Attribute ID Number",
"description": "",
"property_order": 40,
"anyOf": [
"type": "null",
"type": "array",
"items": {
"type": "string",
"title": "Entries"
"Email Address": {
"title": "Email Address",
"description": "$EMAIL",
"property_order": 45,
"anyOf": [
"type": "null",
"type": "string"
"Department ID": {
"title": "Department ID",
"description": "$DEPARTMENTID",
"property_order": 50,
"anyOf": [
"type": "null",
"type": "string"
"Jamf Pro ID of the Configuration Profile": {
"title": "Jamf Pro ID of the Configuration Profile",
"description": "$PROFILEJSSID",
"property_order": 55,
"anyOf": [
"type": "null",
"type": "string"
"Building ID": {
"title": "Building ID",
"description": "$BUILDINGID",
"property_order": 60,
"anyOf": [
"type": "null",
"type": "string"
"Serial Number": {
"title": "Serial Number",
"description": "$SERIALNUMBER",
"property_order": 65,
"anyOf": [
"type": "null",
"type": "string"
"Jamf Pro ID": {
"title": "Jamf Pro ID",
"description": "$JSSID",
"property_order": 70,
"anyOf": [
"type": "null",
"type": "string"
"Department Name": {
"title": "Department Name",
"description": "$DEPARTMENTNAME",
"property_order": 75,
"anyOf": [
"type": "null",
"type": "string"
"Site ID": {
"title": "Site ID",
"description": "$SITEID",
"property_order": 80,
"anyOf": [
"type": "null",
"type": "string"
"Full Name": {
"title": "Full Name",
"description": "$FULLNAME",
"property_order": 85,
"anyOf": [
"type": "null",
"type": "string"
"Building Name": {
"title": "Building Name",
"description": "$BUILDINGNAME",
"property_order": 90,
"anyOf": [
"type": "null",
"type": "string"
"Username": {
"title": "Username",
"description": "$USERNAME",
"property_order": 95,
"anyOf": [
"type": "null",
"type": "string"
Just put the description name into the blank field for this example and then set the scope to your computer..
Example outlook signature script.
loggedInUser=`python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
Title="My Job Title"
Address="Line 1, Post Code"
DirectLine="0800-1234567"
SwitchBoard="0800-1234567"
echo "<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML>
<HEAD>
<TITLE>Default Signature</TITLE>
<META http-equiv=Content-Type content="text/html; charset=windows-1252">
<META content="MSHTML 6.00.6000.21015" name=GENERATOR>
</HEAD>
<body lang=EN-GB link=blue vlink=blue style='font-family:Calibri, Arial, sans-serif; font-size:8.0pt;'>
<span style="font-weight: bold; color: #DA291C; text-transform: uppercase">$loggedInUser</span><br/>
<span style="font-weight: bold; color: #000000">$Title</span><br/><br/>
<span style="color: #000000">My Company Name, $Address</span><br/>
<span style="color: #000000">D: $DirectLine | T: $SwitchBoard</span><br/>
<span style="color: #000000">www.jamfsoftware.com</span><br/><br/>
</body>
"> /Users/"${loggedInUser}"/Documents/Signature/Signature.html
osascript <<EOD
set contentHTML to ("Macintosh HD:Users:$loggedInUser:Documents:Signature:Signature.html") as alias
set contentHTML to (read contentHTML)
tell application "Microsoft Outlook.app"
with timeout of 360 seconds
delete signatures
make new signature with properties {name:"Signature", content:contentHTML}
end timeout
end tell
EOD
This should be enough to get you started.
regards
Steve
