macOS Mass Update - Existing iMacs, Not Prestaged
  • January 6, 2021
  • 0 replies
  • 8 views
What is the recommended workflow for the following scenario?
I would like to use the mass action update command on specific sets of iMac labs. However, the current configurations were developed a while ago and without the use of pre-stage enrollment.
I have looked over the documentation (here) and have confirmed:
  1. that the mass action is the scenario from the workflow chart that I want (retains data and is for minor updates)
  2. that the mass action update command only works on machines enrolled through DEP (or it's newer name/version)
Most of the machines in question appear to have been added manually/semi-manually via QuickAdd packages.
What would be the best approach moving forward with these existing machines? I would like to ensure that data is retained, but also that all available mass action commands are available.
Note: Any new machines now come through our Automated Device Enrollment instance--so hopefully this scenario can be avoided in the future.
