Self Service download: "This App must be associated with a JAMF pro server"
  • May 12, 2020
  • 8 replies
  • 196 views
When trying to download Self Service from the JSS (JAMF cloud), I am met with the above error message. I have performed this ask previously with on premise solutions and had no problem - but it seems unless I automatically install it (which I don't want to do as it will install for everyone) I cannot use the app and test out the functionality.
Is there a way around this?
Best answer by mschroder
Is the device you installed this one enrolled to a JSS?
  • May 12, 2020
  • May 12, 2020
Thanks @mschroder - no, it isn't as I don't want to enroll my own machine....I am guessing I have to for this to work?
Chris_Hafner
Forum|alt.badge.img+27
  • May 12, 2020
Yes. You have to be enrolled to utilize Self-Service.
sbrammer
  • July 9, 2020
i am working on a iOS device and it's enrolled in Jamf Cloud, and i am getting the same error as the OP. I am just getting started as i am about to migrate around 100 iOS devices from another MDM.
Forum|alt.badge.img+20
  • July 9, 2020
@sbrammer , how are you installing Self Service? If are using Device Assignment, make sure you setup App Configuration tab and add the proper config. See this page in docs: Self Service in iOS
We are having the same issues on iPads and iPhones, I noticed that the the issue is occurring after iOS updates, resetting the device and re-enrolling it in pre-stage resolves the issue, but this is not feasible to do .
  • February 3, 2022
Recently any newly added device or reset device is having his issue. We have not made any changes to the self service configuration. The devices are pre-staged. If you delete the app, Jamf will push it down again as all devices are supposed to have the app.
gskibum
  • June 27, 2024
I just ran into this with some new iPads.
Turns out pushing an inventory update command solved it for me.
