Hi all,
So we have JAMF Connect working perfectly in our company but the other day we noticed that there are 1000s of failure logs.
Logging in through the login screen there is a successful login in the azure logs but after that there are failure logs throughout the day.
It looks like it might be the menu app causing these failures when it tries to verify the passwords but I cant pin point what is the problem.
Has anyone else had this issue?
