Tips On Deploying a .pkg file which needs settings .ini to go along
  • February 12, 2016
  • 9 replies
  • 74 views
Team,
I am looking for a solid process that works for deploying a .pkg application via Casper which requires an .INI settings file to be ran along side. The .INI file contains the settings needed for the application to point to the correct server when installation completes. The application in question is Carbon Black.
  • February 12, 2016
Seems like something very similar has already come up today on this discussion: https://jamfnation.jamfsoftware.com/discussion.html?id=18825
Look through those posts to see an example of how to do this.
daz_wallace
  • February 16, 2016
Hi @bjones,
Does the .ini file need to be used during the installation only, or ongoing by the App?
If it's the first, you can use @rtrouton's Office deployment workflow blog, and adapt it to run your install.
If it's the second, I imagine (but test!) you just need the file to be on disk somewhere that the App expects it (maybe /Library/[foo]?). If so, just create a second package with this file to put it in that location.
Hope that helps!
Darren
  • November 30, 2016
@bjones where you able to come up with a solution to deploy the carbon black pkg?
if yes could you please share your solution.
thank you.
  • November 30, 2016
@scentsy
Hey hope all is well... Back when we were using the carbon black application i created a .pkg that went in and placed the files into a tmp directory and ran the executable next to the place .ini files. Once the application was installed and running i place the objects in a smart group referencing systems with com.carbonblack.daemon service running. And to clean up this process i had another script to remove the files that were placed in the tmp directory for installation purposes.
  • December 1, 2016
Hi @bjones
When we have had to deploy things like Carbon Black we use @rtrouton 's method for deploying. Using Packages, drop the script in the "Additional Resources", then use a postflight to call the installer. You don't need any manual cleanup, as the install process will clean up the temp files for you. This way you can also keep your own version history and you can use that to target machines that need newer versions if necessary.
  • December 2, 2016
Perfect, thank you everyone for their responses, that's what I was looking for...thanks!
  • June 9, 2017
you can just zip the files and deploy it like any other .pkg.zip
  • April 18, 2018
This worked perfectly, thanks.
  • October 18, 2023
Hi prbsparx,
could you explain how?
