iPadOS: Awaiting final configuration from loop
  • January 11, 2021
  • 44 replies
  • 707 views
Our organization recently moved over to Jamf Cloud from on-prem hosting. Trying to provision five iPads for a department. Stuck on awaiting final configuration from "our organization" loop. Has anyone experienced this before and if so how did you resolve it? I've already unassigned and reassigned the devices to our MDM in ASM and then wiped the devices in Apple Configurator. Left the iPads running overnight and it was still stuck on awaiting final configuration from "our organization". We had no issues with mobile devices with on-prem hosting.
  • January 11, 2021
Hmmm, I have always been hosted and have not seen this behavior that I can recall in the past 4 years but just this morning trying to wipe some devices, I have 4 iPads that are sitting in this state :(
jphillips
  • January 11, 2021
Yes, we're seeing this on almost all iPads that are on some flavor of 14.x. It will sit at the Awaiting Final MDM Configuration screen, sometimes for a couple of hours, before moving on. Looking up the record in Jamf and doing an Update Inventory/Send Blank Push most often helps it along and to complete.
It seems there is something getting hung up either from Jamf->iPad, or from iPad->Jamf that lets the other know "hey I'm done and ready to move on".
All of our 13.x iPads enroll straight away and do not sit on the screen, which leads me to believe it's an iPadOS 14.x issue.
sjuarez
  • January 11, 2021
I see this sometimes as well on iPads that are running iOS 14.x. What sometimes helps me, when it gets stuck, I just restart the iPad and that will push it through when it gets to that step again. I haven't tried the Update Inventory/Send Blank Push that @jphillips mentioned though. I'll have to try that when I get another one I have to restore.
Forum|alt.badge.img+15
  • January 11, 2021
We see this happening in our environment when our wireless profile gets installed during enrollment. The iPad will switch to the new wireless network, but subsequent MDM commands get queued and won't go through until a Blank Push is sent. This is a new problem with iOS 14 and so far both Jamf and Apple are saying it is expected behavior.
Forum|alt.badge.img+20
  • January 11, 2021
Do you have Install Configuration Profiles before Setup Assistant checked in your PreStage Enrollment? It is possible that a configuration profile is failing to install properly and hanging up the process. Maybe try turning that off and see if you can identify any bad profiles?
  • January 11, 2021
Hello everyone! Thanks for all of you responses. Turns out me connecting the iPads to a mobile hotspot during enrollment got me past waiting for config. Might be an issue with our on prem wifi and networking having to adjust our inbound/outbound traffic for Jamf Cloud: https://www.jamf.com/jamf-nation/articles/409/permitting-inbound-outbound-traffic-with-jamf-cloud
I'll keep everyone in the loop on how we resolve this issue without having to use a mobile hotspot.
atomczynski11
  • January 11, 2021
Hi @anthonydattorro
From your reply, it sounds like you are able to enroll while connected to a mobile hot spot but are experiencing difficulties when using your production network. Is that correct?
Jamf Environment Test - Jet - on github
Apple App Store mobile: Services Test
I have not used the first one to troubleshoot issues, and last time I had to run Services Test was several years ago.
Network Ports Used by Jamf Pro
  • February 3, 2021
This is def a known ongoing issue with Jamf. Opened a ticket with them on Dec 8th and there's still no solution in sight.
  • February 4, 2021
@GBeau Agreed. I too have open a ticket for this. Very reproduceable. I am also hoping for a response. I had to remove my profiles from installing during the PreStage like @RBlount mentioned. The only issue now is that some times, hit or miss when provisioning new devices they will hang after the setup assistant is done for like a hour until they pull their configuration profiles. Blank pushes, inventory update, etc, don't do anything. Since you can not set iPads to update more than once a day this really stinks because you either have to wipe the device or look them up individually to be able to check and re check it they are now able to get the configuration profiles.
I am hoping this gets attention as it is a serious issue.
  • February 4, 2021
I'm not sure whether or not we're all dealing with the exact same issue, but Jamf did assign an official product issue to my problem. If you're dealing with this issue where you're seeing an iPad stuck at awaiting final configuration after enrollment and you have MDM commands queued up, reference PI-009296 with Jamf support.
@jphillips "Looking up the record in Jamf and doing an Update Inventory/Send Blank Push most often helps it along and to complete." This did the trick for me. Only seeing it with the 14.x iPads.
  • February 5, 2021
We have been having a similar issue. Like @RBlount said, unchecking the Install Configuration Profiles before Setup Assistant checkbox fixed this for us.... though it does make the wipe and reset process a little more involved.
jphillips
  • February 6, 2021
Unfortunately that doesn’t work for us. We’ve never had the option in prestages on and we still get the Awaiting hang on every 14.x iPad.
Update for those that might still be experiencing this: Unchecking "Set Time Zone" in the prestage seems to have solved this hang. I was trying to enroll a 14.4 iPad all morning, about 4 times, but it kept hanging. Unchecked the the Set Time Zone option and the iPad enrolled immediately.
  • February 8, 2021
That's very strange. We have never had the "Set Time Zone" option checked..... wonders never cease.
  • February 9, 2021
So as per @nbdavis @RBlount and @cbrewer this is definitely caused by install profiles before setup assistant - we have now turned this off.
What we see is that the command 'device configured' is stuck in the list of pending tasks which is stopping the handoff from setup assistant. We clear all commands APART FROM device configured, send a blank push which has seemed to be a successful workaround......
realjaack
  • February 10, 2021
Try unchecking the "Set Time Zone" in pre-stage. They asked us to do that and it seems to have resolved this immediately for us for now. Good luck, all!
  • February 11, 2021
I also have an open ticket for this issue. Ticket was opened on 12/2/2020 and still have no resolution. Right now I'm trying unchecking the option to install config profiles before setup assistant fix, but we've never used the 'Set Time Zone' option.
With 10.5k student iPads in a remote learning environment, it's getting incredibly frustrating that our help desk is too afraid of this issue to have a student reset and re-enroll their iPad to try and resolve issues.
Also, we're on-prem running 10.27.0, so it's not limited to cloud customers.
  • February 12, 2021
@cbrewer Did they close your PI? I can't find a reference to PI-009296 on the Known Issues page.
  • February 12, 2021
I tried unchecking Install configuration profiles before Setup Assistant in my prestage and it did successfully get my test device through Setup Assistant and to it's home screen. However, now instead of DeviceConfigured being the command that's getting stuck, the initial Submit Inventory is getting permanently stuck. This means that my test iPad never fell into the multiple smart groups it should have, and therefore failed to receive most of it's config profiles and managed apps. That makes it an untenable workaround for us.
It's worth noting, though, that that test device does successfully receive other management commands. Upon enrollment, it received and executed the commands to install a five apps and four config profiles that are scoped to 'All Devices'. It also successfully received and executed the Renew MDM Profile and Restart Device commands I manually issued. However, it failed to receive Settings - Disable Bluetooth, EnableLostMode, and PlayLostModeSound that I manually issued.
  • February 24, 2021
My cloud server was updated to 10.27 about a week ago and we immediately started having this issue. I'm able to get to get past the awaiting final configuration loop and to the home screen by deselecting time-zone (iOS 14 or later) and Install Configuration Profiles before Setup Assistant, but it hangs up there with an Update Inventory as previous posts stated. I've tried a blank push, restart, another wipe but can't get config profiles, apps, or smart groups on the device. Self Service is also not working for iPads, so it's causing quite a few headaches. Anyone else find a resolution?
realjaack
  • February 25, 2021
It looks like this is resolved for now by going into your PreStages and unchecking the "Set Time Zone" box. Good luck!
  • February 25, 2021
We've never had the "Set Time Zone" box checked and are having the issue. Unchecking "Install Configuration Profiles before Setup Assistant" gets a device to the home screen, but configs and apps won't come down reliably.
realjaack
  • March 1, 2021
  • March 3, 2021
For those interested, we've been assigned a product issue (PI-009403). We have some apps scoped as autoinstall and some of those same apps scoped to be in self service. If there's any device overlap between the 2, we get this issue. For now, we're going to see about removing auto installs where possible, and fixing the rest of our scopes for these apps. Really hoping that takes care of it. It'd sure be nice if the backend were smarter about licensing and idiot proofing this sort of thing...
  • April 14, 2021
Bumping this as we began experiencing the same issue early in March after renewing our Certificate Authority. I've tried unchecking "Install configuration profiles before Setup Assistant" in our prestage setting and it lets us finish enrollment, but the iPads stop receiving/processing management commands shortly afterwards and never complete their app deployments.
We've never had Set Time Zone checked.
The only solution we've been able to find is to delete the iPad from Jamf Pro and restore it so it can go through enrollment again. If the device isn't removed from Jamf Pro first, it just gets stuck at "Awaiting final configuration" again and you have to restore it again. This is obviously a huge, time-consuming, pain in the butt.
