Unable to use DELETE function in JAMF School API
  • May 19, 2020
  • 10 replies
  • 23 views
Hello,
I'm trying to use the DELETE API in the JAMF School API but without success. What am I doing wrong ?
curl -X DELETE -H "Accept:application/json" -H "X-Server-Protocol-Version: 3" -H "Authorization: Basic xxxxxxxx" https://apiv6.zuludesk.com/users/:3801107
{"code":404,"message":"UserNotFound"}
curl -X DELETE -H "Accept:application/json" -H "X-Server-Protocol-Version: 3" -H "Authorization: Basic xxxxxxx" https://apiv6.zuludesk.com/users/3801107
Thank you,
Antonio
  • May 19, 2020
Forgot to mention that the user 3801107 exists in our JAMF School database :)
  • May 19, 2020
Hi @asaraca,
The:
May need to be:
https://apiv6.zuludesk.com/JSSResource/users/id/3801107
Or if 3801107 it is the name:
https://apiv6.zuludesk.com/JSSResource/users/name/3801107
Also, I know json and Jamf's Api integration can sometimes get tricky
@iMatthewCM Has a great set of jamf API scripts on his Github
  • May 20, 2020
Still not working :(
curl -X DELETE -H "Accept:application/json" -H "X-Server-Protocol-Version: 3" -H "Authorization: Basic xxxx" https://apiv6.zuludesk.com/JSSResource/users/name/3801107
{"error":{"code":404,"message":"Not found"}}
curl -X DELETE -H "Accept:application/json" -H "X-Server-Protocol-Version: 3" -H "Authorization: Basic xxxx" https://apiv6.zuludesk.com/JSSResource/users/id/3801107
  • May 20, 2020
In it's simplest form, this should work:
curl -sku "Username":"Password" "https://apiv6.zuludesk.com/JSSResource/users/id/3801107" -X DELETE
If you need to use with base64 authorization:
curl -sk -H 'authorization: Basic xxxxxxx' "https://apiv6.zuludesk.com/JSSResource/users/id/3801107" -X DELETE
There are some great Jamf API videos online including:
Getting Started With the Jamf API Part 1 – Kitzy
Hands on with the Jamf Pro API Part 1
  • May 21, 2020
It still doesn't work. The problem I think is that we are using JAMF School and not JAMF Pro and the API don't seem to work the same way :(
afarnsworth
  • May 21, 2020
Using https://apiv6.zuludesk.com/docs/#api-Users-Delete as a reference
Your curl command should look like:
curl -X DELETE "https://api.zuludesk.com/users/:id" --header "Content-Type: application/x-www-form-urlencoded; charset=utf-8" --header "Authorization: Basic xxxxx"
Does it work if you add the Content-Type to the header?
  • May 25, 2020
Sadly no, I still have the "user not found" error.
  • May 25, 2020
Finally I found the error: the id is not the id in the JAMF School web interface, but the id returned by the API.
  • May 27, 2020
I don't know why but I am facing a similar kind of issue with the API.
  • June 6, 2023
@afarnsworth Kindly let me know what's that content-type? As I'm getting below error message when I use Delete parameter in curl.
