Extension Attribute Help
  • January 16, 2021
  • 44 views
KyleEricson
I need to setup extension attribute to monitor for bad display dongles.
Using fitHeadless4k display dongles.
system_profiler SPDisplaysDataType shows both good and bad macs reporting the same "Display". However, the color profile on the bad macs is sRGB IEC61966-2.1 and the good macs is fitHeadless4k.
Best answer by dan-snelson
@keric The following is largely untested as I don't find a match for "color" in my output for system_profiler SPDisplaysDataType, so I searched for the display's serial number. Change "Display Serial Number" to your search term. (Remove set -x and set +x when you're done testing.) As always, YMMV.
# An Extension Attribute to detect external display serial number. #
# If not applicable, "Not Applicable" will be returned.            #
set -x
RESULT="Not Applicable"
displayTypeData=$( /usr/sbin/system_profiler SPDisplaysDataType )
displaySerialNumber=$( /bin/echo ${displayTypeData} | /usr/bin/grep "Display Serial Number" | /usr/bin/awk -F ': ' '{print $NF}' )
if [[ -n "${displaySerialNumber}" ]]; then
    RESULT=${displaySerialNumber}
echo "<result>$RESULT</result>"
set +x
dan-snelson
Forum|alt.badge.img+30
  • January 16, 2021
set -x
set +x
KyleEricson
  • January 17, 2021
@dan-snelson Thanks so much had to change a few things this is what I ended up with using.
#!/bin/zsh
# An Extension Attribute to detect external display dongle. #
# If not present, "No" will be returned.#
RESULT="No"
displayTypeData=$( /usr/sbin/system_profiler SPDisplaysDataType | /usr/bin/grep "fit" )
displayinfo=$( /bin/echo ${displayTypeData} )
if [[ -n "${displayinfo}" ]]; then
    RESULT="Yes"
