Hello, I'm currently on the task of configuring IPads for our schools. I was able to insert the IPads into Jamf, was able to store DEP profiles and have already distributed the profiles to some of the devices. Unfortunately, after a while or any actions, the devices lose their profile and all the features and apps are unlocked again. Is a profile setting set incorrectly there, or can it be for other reasons?
I would be pleased to see solutions.
Thank you very much
Be the first to reply!
