Deploying Malwarebytes Endpoint Agent
  • January 22, 2021
  • 13 replies
  • 119 views
After a LOT of head banging, I finally am able to deploy Malwarebytes Endpoint Agent to computers via JAMF. I wanted to share to help others who may be looking for assistance. Please feel free to tweak any of this as there may be better ways, but this worked for me.
FYI … this is the deployment method that worked for me in JAMF
1) Log in to the Malwarebytes Nebula platform.
2) Go to Downloads.
3) In the Mac section, click Download to download the Mac Endpoint Installer to your local device.
4) For JAMF the brackets [ ] are incompatible, replace the PKG filename brackets to an underscore enclosing the account token.
File name downloaded Setup.MBEndpointAgent[xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx]_.pkg
New file name Setup.MBEndpointAgent__xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx__.pkg*
5) Upload the renamed package to JAMF
6) Upload & Scope “Malwarebytes KEXT Whitelist
7) Upload & Scope “Privacy Settings Whitelist - Malwarebytes Protection
8) Create script to register the installation with Nebula
cd /Library/Application Support/Malwarebytes/Malwarebytes Endpoint Agent/EndpointAgentDaemon.app/Contents/MacOS/
sudo ./EndpointAgentDaemon ACCOUNTTOKEN=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
sudo launchctl stop com.malwarebytes.agent.daemon
sudo launchctl start com.malwarebytes.agent.daemon
exit
9) Create & Scope a Policy to Install the package & run the script (set script to run AFTER)
10) Deploy
  • January 22, 2021
Thanks for posting. I believe you'll want to remove the "sudo"s from the script for best results, since it will run as a Jamf policy.
  • March 4, 2021
Not exactly sure why but I'm getting an exit code of 139 using this script
mani2care
  • March 24, 2021
Malwarebytes uninstall script anything is available?
Thanks for posting!
Where do you get the below info?
Specifically, where do you get the "accounttoken"?
  • November 9, 2022
The account token is in the filename.  It is all the "x"'s
  • June 27, 2023
Hey @timbrownell ,
Thank you for these details and it works for me.
But did you set up the extension attribute as well?
If yes then can you please share a script of that?
  • June 27, 2023
  • June 27, 2023
I am looking for an extension attribute script. so through extension attributes, we can see the Marwalebytes are in the system and active or deactivate.
Attaching a screenshot for idea. we used ESET Endpoint before and now start using Marwalebytes.
  • June 27, 2023
No I do not have that.  Once installed I manage via the Nebula dashboard.
  • June 27, 2023
I see, Thank you.
  • June 27, 2023
@smpatel We use 2 EA's, one for installed and the other for running.  They are really simple, so I am not sure this is what you are looking for or not.
#!/bin/zsh ############################################################################################### # # Script Name: MalwareBytes Extension Attributes # Date: 05/02/2023 # Purpose: Simple script to check if the MalwareBytes is installed # # Target: All computers # Written by: chelm # ############################################################################################### MBApp="/Library/Application Support/Malwarebytes/Malwarebytes Endpoint Agent/UserAgent.app" if [[ -d $MBApp ]]; then echo "<result>Pass (Installed)</result>" else echo "<result>Fail (Not Installed)</result>" fi exit
#!/bin/zsh ############################################################################################### # # Script Name: MalwareBytes Extension Attributes # Date: 05/02/2023 # Purpose: Simple script to check if the MalwareBytes process is running # # Target: All computers # Written by: chelm # ############################################################################################### PROCESS='UserAgent' number=$(ps aux | grep -v grep | grep -ci $PROCESS) if [[ $number -gt 0 ]]; then echo "<result>Pass (Running)</result>" else echo "<result>Fail (Not Running)</result>" fi exit
Does that help?
  • August 24, 2023
@chelm Thanks, It works for me to see in the extension Attribute.
Sorry for the replying delay.
