Hi there, i'm having some issues regarding Configuration profiles -> Web Clips
This might just be doing something wrong since it was quite a while ago i used jamf, but i'm trying to setup a new Web Clip payload and all works great except for the "Label".
I'm trying to deploy a Webclip called "This & That" but as soon as i type this in it just shows up as "This&That".
It completely disregards the "spaces", if we are cheking in the MDM profile on the ipad itself it looks correct, but in the homescreen it just "deletes" the spaces.
Any idea why this is happening?
We have 5 other Webclips where it is "correct".
Thanks for posting this issue.
I am experiencing the exact same thing.  Were you able to find a resolution?
