Calculate Free Space - Catalina
  • June 4, 2020
  • 48 views
I'm trying to calculate free space on Catalina. For prior versions of macOS, this piece from a script from Joshua Roskos' macOS Upgrade script works:
diskInfoPlist=$(/usr/sbin/diskutil info -plist /)
    ## 10.13.4 or later, diskutil info command output changes key from 'AvailableSpace' to 'Free Space' about disk space.
    freeSpace=$(
    /usr/libexec/PlistBuddy -c "Print :FreeSpace" /dev/stdin <<< "$diskInfoPlist" 2>/dev/null || /usr/libexec/PlistBuddy -c "Print :AvailableSpace" /dev/stdin <<< "$diskInfoPlist" 2>/dev/null
But on Catalina, the result is "0" every time. The FreeSpace key that is generated by:
is always "0" on Catalina. What needs to be changed to get the correct value for FreeSpace?
PaulHazelden
  • June 4, 2020
Hi I use....
df -m /Volumes/Macintosh HD | awk '{print $4}' | grep -v "Available"
And it shows the number of Mb available, divide by 1024 to get Gb
rcole
  • July 26, 2021
Hi I use....
This is interesting and helfpful @PaulHazelden  — Is this able to be used in Big Sur as well as Catalina as an extension attribute with as an Integer?
PaulHazelden
  • July 26, 2021
Yes the code works in Big Sur, it is Bash. You would need to set it up to publish its results to make it into an EA.
I use it to report space to the user with a notification popup. Our Macs get a lot of the user space cleared out every day, but some of the students working on Movies can get a bit carried away and drop a serious amount of files on the hard drive. So they get warnings.
