Check whether AD Domain Controllers are responding
  • June 9, 2020
  • 47 views
dlondon
We have quite a few AD Domain controllers. I recently was investigating logon delays so one thing I was looking at was whether all the Domain Controllers could be reached.
Each of the following in terminal returned the same list of servers from DNS:
host -t SRV _ldap._tcp.my.domain.name
host -t SRV _kerberos._tcp.my.domain.name
host -t SRV _kpasswd._tcp.my.domain.name
host -t SRV _gc._tcp.my.domain.name
I then attempted to connect to each of the machines using telnet to each of the ports for ldap, kerberos, kpasswd and gc - 389, 88, 464 and 3268
The results quite quickly showed that something was blocking access to some Domain Controllers (DC's) on the subnet I was trying to sort out. Even though the DC's could be pinged. Our friendly Firewall Guy helped and found that 3 of the 9 DC's were not in the rule allowing access.
What I am wondering is whether anyone has worked out a way to automate this sort of check - see if each of the DC's listed in DNS is responding on the correct port. The way I was checking was with Telnet and by default that is not installed any more
Best answer by merps
You should be able to check this using netcat, installed by default.
nc -z 10.xx.yy.zz 3268
Connection to 10.xx.yy.zz port 3268 [tcp/msft-gc] succeeded!
nc -z 10.xx.yy.zz 464
Connection to 10.xx.yy.zz port 464 [tcp/kpasswd] succeeded!
nc -z 10.xx.yy.zz 88
Connection to 10.xx.yy.zz port 88 [tcp/kerberos] succeeded!
nc -z 10.xx.yy.zz 389
Connection to 10.xx.yy.zz port 389 [tcp/ldap] succeeded!
To run it in a script, macOS has a required flag -G to handle connection timeout for unresponsive hosts.
nc -z -G 2 10.xx.yy.zz 3268 &> /dev/null && echo "Online" || echo "Offline"
  • June 9, 2020
dlondon
  • June 9, 2020
Thanks @merps (Michael) - much appreciated especially the usage tip - it's like you read my mind.
