ForeScout agent deployment - Script
  • February 9, 2021
  • 0 replies
  • 113 views
Hey, So, after lots of tests and struggling with new ways to migrate DMG file to PKG I found that none of them really works and the agent never starts and works properly...
I found this script (don't remember where) and this solved my issue!
!/bin/sh
Downloading OSX Update Package to /tmp on the host
curl -o /tmp/update.tgz http://YOUR_SERVER_NAME_OR_IP/SC_packages/update.tgz; sleep 3
Extracting update.tgz to /tmp
tar -zxvf /tmp/update.tgz -C /tmp; sleep 3
Installing SecureConnector as a Daemon/Dissolvable w/ visible/invisible menu bar icon
sudo -S /tmp/Update/Update.sh -t daemon -v 1; sleep 3
Checking/Starting processes in case they did not start on install
daemon_pid=ps auxww | grep -v grep | egrep "ForeScout SecureConnector.-daemon" | awk '{print $2}'
agent_pid=ps auxww | grep -v grep | egrep "ForeScout SecureConnector.-agent" | awk '{print $2}'
daemon_plist=/Library/LaunchDaemons/com.forescout.secureconnector.daemon.plist
agent_plist=/Library/LaunchAgents/com.forescout.secureconnector.agent.plist
if [[ -z "$daemon_pid" && -z "$agent_pid" ]]; then #Starting Daemon process launchctl unload $daemon_plist launchctl load $daemon_plist
Starting GUI process launchctl unload $agent_plist launchctl load $agent_plist
elif [[ ! -z "$daemon_pid" && -z "$agent_pid" ]]; then #Starting GUI process launchctl unload $agent_plist launchctl load $agent_plist
Clean-up a little
sudo rm -rf /tmp/update.tgz /tmp/Update/
I hope this will help the other guys that having the same issue as I had :) Cheers!
