an error occurred while obtaining automatic configuration settings Pre Stage
  • February 13, 2021
  • 28 replies
  • 394 views
I am running into an issue on big sur with prestage enrollments. After passing language and wifi, I run into the error stated above "an error occurred while obtaining automatic configuration settings" on the remote management screen. I have followed the vidoes and set my prestage to the same settings, yet big sur will not pull the configurations. On Jamf Pro 10.27. Any help would be appreciated.
Forum|alt.badge.img+15
  • February 19, 2021
I am seeing the same thing. It's odd because it works on the same machine with an internet recovery of Mojave...
  • March 31, 2021
We just got this error too, doing more data gathering. Anyone figure out what the issue was and how to fix? Thanks
  • March 31, 2021
Ive had a it a handfull of times also. in all of my cases ive ended up shoving the machine aside and looking at it a day or two later and it magically works.
I wonder if Apple have some sort of rate limiting or something on how many times in a day you can do an internet recovery / DEP lookup thing.
  • April 5, 2021
I have the same issue. I been trying for two days now.
I have the same issue, was there ever any resolution to this?
  • May 10, 2021
Same issue here on one specific MacBook. Will try a Catalina install and see where that gets me.
Edit: no dice.
  • May 12, 2021
`im currently getting the same on MBP Intel with 11.3.1 installed ..
Any ideas?
dstranathan
Forum|alt.badge.img+19
  • May 14, 2021
Just got a call from a colleague on this error today (while re-enrolling an existing Intel 2019 MacBook Pro 13" that shipped with Catalina but had Big Sur 11.3 installed).
We recently rebuilt our PreStage Enrollment settings (per a Jamf Support call 3 weeks ago), but we have enrolled ~5 new M1 and Intel Macs (Big Sur 11.2.3 & 11.3.1) since then with no DEP/AMB/PreStage issues.
Any thoughts on the cause of this?
dstranathan
  • May 17, 2021
Solved:
Per Jamf Support, we simply zapped the PRAM on the affected Mac (2019 Intel MacBook Pro), and now the Mac can pull our DEP PreStage and enroll into Jamf management.
  • May 18, 2021
I had the same issue with a 2019 MBP as well.
I can confirm that resetting the PRAM worked.
Thank you.
  • May 18, 2021
Also, it appears you need to reset the PRAM every time. After enrolling and running through my install workflows I went ahead and reset the device again to see if the error could be reproduced. I did get the same error message again and once again the error was resolved by resetting the PRAM.
  • May 18, 2021
And, Finally, I did a PRAM reset BEFORE doing a wipe and reinstall and I still go the same error message. I needed to reset the PRAM again to complete enrollment. This is problematic as it breaks my MDS deployment workflow.
  • May 19, 2021
Im not sure what happened, but every new MacBook we have purchased seems to be working. We added an enrollment customization as well after this started to work.
I am curious if the new hardware works due to the OS that comes preinstalled.
I never got around to test the PRAM but I will be happy to update this more when we get an older MacBook returned that is part of our DEP
I had the same issue on a Mac and can confirm that zapping the PRAM did solve the issue. Thanks for the heads-up.
  • June 8, 2021
Wow. Thank you for the Resest-NVRAM fix. I had only ever seen this on MacBook that had had its motherboard replaced. Figured that was the problem for some weirdo reason.
  • June 9, 2021
Thank you! the Reset of the PVRAM fixed the issue. I am able to enroll my test macOS device.
Thanks for sharing!
  • August 3, 2021
You guys all rock.  The PRAM reset worked for me also.  Thanks for sharing.
oli
  • August 4, 2021
Solved:
Thank you very much for sharing this solution! After hours of trying, I found this Post and your solution!
user-CqUlRTAQgf
Solved:
Hi I've tried that sour time and it hasn't worked any other solution ?
  • November 11, 2021
Solved:
This worked for me - Thanks!
  • December 3, 2021
+1 for the PRAM solution here as well. Now the Mac showed the Hello welcome step as well before stating the Monterey setup, it didn't before.
  • December 8, 2021
Solved:
Thanks for this I've been pulling my hair out for about 2 hours now and this did the trick.
dstranathan
  • December 9, 2021
I have seen this 2 or 3 more times over the summer/fall. Zapping the PRAM has done the trick every time.
rtylerdavis
  • Employee
  • January 12, 2022
Solved:
I was just in the same boat as everyone replying to this and this did the trick immediately. Super frustrating for like 2 hours and then nailed it.
  • January 28, 2022
Glad I stumbled across this... I'm trying to test a prestage with a Monterey guest on Virtualbox.
Unfortunately nvram -c doesn't seem to be up to the task of resetting the PRAM...
I wonder if I have to zap the PRAM on the host?
