10.9 & Casper 9 policies run manually
  • August 30, 2013
  • 0 replies
  • 0 views
Anyone testing 10.9 & Casper 9?
Are you having a problem where if you run a policy via custom trigger from CLI the policy fails to run?
If i do sudo jamf policy -trigger MyCustomTrigger
the jamf binary checks for policies, finds the policy and then attempts to mount the repository, but never mounts it and the command stalls and stays there forever
the distribution point is win2k12 using extremezip. same issue using a DP that is running ubuntu 12 with netatalk 3.0.5
dont need specifics but a yes im having the issue as well or a no, no issue here would be awesome
