Installing Apple Configurator 2 VPP
  • February 18, 2021
  • 20 views
I'm having issues with installing Apple Configurator 2 in Self Service. I've "bought" the app via VPP. When I (or anyone else in our organization) click on the Self Service policy it fails and opens the App Store object for AC2. All other apps via VPP is working normally. It's only AC2 that's not working.
I get this error message in the log which is not that helpful (to me):
[2021-02-17 12:54:02] Error occurred while attempting mdm action: Error Domain=com.jamfsoftware.jamfappcommerror Code=100 "(null)" UserInfo={HTTP Status Code=500}
I've bought licenses in ASM and assigned them to the AC2 policy in JSS. I'll attach some screenshots. Does anyone else have this problem?
1 reply
  • July 29, 2021
Did you happen to find a solution for this issue? Im running into the same thing after my recent JSS upgrade
