Hello everyone I've tried so far has crabs and they always keep crashing the app after updating it any advice
Script No 1:
!/bin/sh
# ABOUT THIS PROGRAM
NAME
ZoomInstall.sh -- Installs or updates Zoom
SYNOPSIS
sudo ZoomInstall.sh
# HISTORY
Version: 1.1
1.1 - Shannon Johnson, 27.9.2019
Updated for new zoom numbering scheme
Fixed the repeated plist modifications
# 1.0 - Shannon Johnson, 28.9.2018
(Adapted from the FirefoxInstall.sh script by Joe Farage, 18.03.2015)
Script to download and install Zoom.
Only works on Intel systems.
Set preferences
hdvideo="true"
ssodefault="true"
ssohost="xxx.zoom.us"
choose language (en-US, fr, de)
lang=""
CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 1 AND, IF SO, ASSIGN TO "lang"
if [ "$4" != "" ] && [ "$lang" == "" ]; then
lang=$4
lang="en-US"
pkgfile="ZoomInstallerIT.pkg"
plistfile="us.zoom.config.plist"
logfile="/Library/Logs/ZoomInstallScript.log"
processname="zoom.us"
killall "$processname" &> /dev/null
if [ $? -eq 0 ]; then
echo "Killing $processname"
Are we running on Intel?
if [ '/usr/bin/uname -p
'="i386" -o '/usr/bin/uname -p
'="x86_64" ]; then
## Get OS version and adjust for use with the URL string
OSvers_URL=$( sw_vers -productVersion | sed 's/[.]/_/g' )
## Set the User Agent string for use with curl userAgent="Mozilla/5.0 (Macintosh; Intel Mac OS X ${OSvers_URL}) AppleWebKit/535.6.2 (KHTML, like Gecko) Version/5.2 Safari/535.6.2"
# Get the latest version of Reader available from Zoom page. latestver=$(/usr/bin/curl -s -A "$userAgent" https://zoom.us/download | grep 'ZoomInstallerIT.pkg' | awk -F'/' '{print $3}') echo "Latest Version is: $latestver"
# Get the version number of the currently-installed Zoom, if any. if [ -e "/Applications/zoom.us.app" ]; then currentinstalledver=$(/usr/bin/defaults read /Applications/zoom.us.app/Contents/Info CFBundleVersion) echo "Current installed version is: $currentinstalledver" if [ ${latestver} = ${currentinstalledver} ]; then echo "Zoom is current. Exiting" exit 0 fi else currentinstalledver="none" echo "Zoom is not installed" fi
url="https://zoom.us/client/${latestver}/ZoomInstallerIT.pkg"
echo "Latest version of the URL is: $url"
echo "date
: Download URL: $url" >> ${logfile}
# Compare the two versions, if they are different or Zoom is not present then download and install the new version. if [ "${currentinstalledver}" != "${latestver}" ]; then
# Construct the plist file for preferences echo "<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>nogoogle</key> <string>1</string> <key>nofacebook</key> <string>1</string> <key>ZDisableVideo</key> <true/> <key>ZAutoJoinVoip</key> <true/> <key>ZDualMonitorOn</key> <true/>" > /tmp/${plistfile}
if [ "${ssohost}" != "" ]; then echo " <key>ZAutoSSOLogin</key> <true/> <key>ZSSOHost</key> <string>$ssohost</string>" >> /tmp/${plistfile} fi
echo "<key>ZAutoFullScreenWhenViewShare</key> <true/> <key>ZAutoFitWhenViewShare</key> <true/>" >> /tmp/${plistfile}
if [ "${hdvideo}" == "true" ]; then echo "<key>ZUse720PByDefault</key> <true/>" >> /tmp/${plistfile} else echo "<key>ZUse720PByDefault</key> <false/>" >> /tmp/${plistfile} fi
echo "<key>ZRemoteControlAllApp</key> <true/> </dict> </plist>" >> /tmp/${plistfile}
# Download and install new version
/bin/echo "date
: Current Zoom version: ${currentinstalledver}" >> ${logfile}
/bin/echo "date
: Available Zoom version: ${latestver}" >> ${logfile}
/bin/echo "date
: Downloading newer version." >> ${logfile}
/usr/bin/curl -sLo /tmp/${pkgfile} ${url}
/bin/echo "date
: Installing PKG..." >> ${logfile}
/usr/sbin/installer -allowUntrusted -pkg /tmp/${pkgfile} -target /
/bin/sleep 20
/bin/echo "date
: Deleting downloaded PKG." >> ${logfile}
/bin/rm /tmp/${pkgfile}
#double check to see if the new version got updated
newlyinstalledver=$(/usr/bin/defaults read /Applications/zoom.us.app/Contents/Info CFBundleVersion)
echo "Version on Mac is ${newlyinstalledver}"
if [ "${latestver}" = "${newlyinstalledver}" ]; then
/bin/echo "date
: SUCCESS: Zoom has been updated to version ${newlyinstalledver}" >> ${logfile}
echo "Zoom updated successfully"
# /Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType hud -title "Zoom Installed" -description "Zoom has been updated." &
/bin/echo "date
: ERROR: Zoom update unsuccessful, version remains at ${currentinstalledver}." >> ${logfile}
/bin/echo "--" >> ${logfile}
echo "Zoom not updated - Installation error"
exit 1
# If Zoom is up to date already, just log it and exit.
/bin/echo "date
: Zoom is already up to date, running ${currentinstalledver}." >> ${logfile}
/bin/echo "date
: ERROR: This script is for Intel Macs only." >> ${logfile}
No2:
!/bin/bash
this is the full URL
url="https://zoom.us/client/latest/ZoomInstallerIT.pkg"
change directory to /private/tmp to make this the working directory
cd /private/tmp/
download the installer package and name it for the linkID
/usr/bin/curl -JL "$url" -o "ZoomInstallerIT.pkg"
install the package
/usr/sbin/installer -pkg "ZoomInstallerIT.pkg" -target /
remove the installer package when done
/bin/rm -f "ZoomInstallerIT.pkg"
