New Patch Policy Extension Attribute Errors
  • March 4, 2021
  • 8 replies
  • 69 views
Our cloud asset was recently upgraded to 10.27
There are new Patch Policies available and a handful of "Legacy" and "Deprecated" Software Titles.
I'm seeing EA errors for the Patch Management of Microsoft AutoUpdate and for Mozilla Firefox.
I'm no EA wizard, but I don't see anything obvious in the EA provided by the Patch Management.
Anyone else seeing this?
Best answer by JG3741
Please refer to this article: https://www.jamf.com/jamf-nation/discussions/38253/jamf-pro-patch-feed-updates
  • March 4, 2021
  • March 4, 2021
The Firefox and OneDrive EA's are now broken.
  • March 5, 2021
@GSKYadmin I got the fix from another discussion: Go to the EA that is broken/showing error. Click Edit. Then there is an Accept button. Click that. There will be a popup with a checkbox. Check it and click Ok. EA should be better.
  • April 7, 2022
I found that I cannot edit the extension attribute. For instance, some folks are failing on OneDrive, because the CFBundleIdentifier is different (should be com.microsoft.OneDrive but is actually com.microsoft.OneDrive-mac)
henrybryan1
  • March 14, 2023
This fixed my issue in two clicks. Thanks!
  • March 15, 2023
This fixed mine too. Thank you!!
  • March 24, 2023
Fixed it for me. If jamf is following this thread, this is a stupid problem to have. How about explaining this in the EA page.
  • July 25, 2023
Thank you for this solution! Cant believe it was so simple lol!
