Xcode 12 not installing via self service
  • March 5, 2021
  • 8 replies
  • 84 views
dlondon
I have Xcode 12 as a VPP app assigned via Apple School Manager to our Jamf Pro server
Just rebuilt a machine and tried installing Xcode and it looks to install but finishes way too quickly and doesn't install. No message of a failure and nothing in the Jamf inventory for the machine. Lots of other VPP apps are installing - Pages, Numbers, Keynote
Apart from downloading it direct, are there any other ideas of things to check?
  • March 23, 2021
I have yet to find a resolve for Xcode 12 installing via Jamf and would much like to find a fix as well as find a way to update existing installations that were installed directly form the App store versus a Jamf deployment.
  • April 30, 2021
Has this been resolved? If so, what was the solution?
  • May 14, 2021
I have just opened a ticket regarding this these are the errors I have found:
Error installing content: Xcode
com.apple.xpc.launchd[1]: Coalition Cache Hit: app<application.com.apple.dt.Xcode.22961078.23627245(503)> [3119]
com.apple.xpc.launchd[1] (application.com.apple.dt.Xcode.22961078.23627245[9999]): Service exited due to SIGABRT
com.apple.xpc.launchd[1] (application.com.apple.dt.Xcode.22961078.23627245[9832]): Service exited due to SIGTERM | sent by Dock[617]
Not to sure what they mean, waiting until they get back to me
  • June 10, 2021
I have also opened a support case for this: JAMF-2900787
  • June 16, 2021
We now have this issue as well. Opened a ticket.
  • July 23, 2021
There are many threads out there on challenges installing Xcode esp via VPP where due to its size some kind of timeout or download interrupt occurs. In my org we've had better success grabbing the xip from the Apple developer site and redistributing / unpacking that to clients. Not pretty, very space consuming (you'll want upwards of 40GB free just in case) and manage users' expectations to have a LOT of patience.
  • September 9, 2021
How did Jamf fix this?
  • October 5, 2021
What is seen here, is that on XCode install from "Self Service" it shows an error ("Failed").
This operative leaves that, and then as root in the terminal:
find /private -name '*.pkg' 2>/dev/null
You'll see it there (if the VPP god is smiling on you) with a randomized filename and when run again you'll see it's still alive, downloading... file size growing. When a bit more than 11 Gigs,  and stops increasing in size, run:
installer -pkg /private/var/...{whatever} -target /
Even that may take 20-30 minutes to complete, but usually does.
The mistake is in taking the Error at face value and clicking "Install" again, or "Open" (which sometimes appears), all is muddied in that case...
