Hi Guys,
After deploying the DMG on applications folder, the following commande ligne doesn't work for me, it's seems like there is a timeout on the machines, but it's working manually from terminal,
"/Applications/Install macOS Big Sur.app/Contents/Resources/startosinstall" --agreetolicense --forcequitapps --nointeraction
results :
Running command "/Applications/Install macOS Big Sur.app/Contents/Resources/startosinstall" --agreetolicense --forcequitapps --nointeraction...
Result of command:
By using the agreetolicense option, you are agreeing that you have run this tool with the license only option and have read and agreed to the terms.
If you do not agree, press CTRL-C and cancel this process immediately.
Preparing to run macOS Installer...
Preparing: 0.0% Preparing: 0.1% Preparing: 0.2% Preparing: 0.3% Preparing: 0.4% Preparing: 0.5% Preparing: 0.6% Preparing: 0.7% Preparing: 0.8% Preparing: 0.9% Preparing: 1.0% Preparing: 1.1% Preparing: 1.2% Preparing: 1.3% Preparing: 1.4% Preparing: 1.5% Preparing: 1.6% Preparing: 1.7% Preparing: 1.8% Preparing: 1.9% Preparing: 2.0% Preparing: 2.1% Preparing: 2.2% Preparing: 2.3% Preparing: 2.4% Preparing: 2.5% Preparing: 2.6% Preparing: 2.7% Preparing: 2.8% Preparing: 2.9% Preparing: 3.0% Preparing: 3.1% Preparing: 3.2% Preparing: 3.3% Preparing: 3.4% Preparing: 3.5% Preparing: 3.6% Preparing: 3.7% Preparing: 3.8% Preparing: 3.9% Preparing: 4.0% Preparing: 4.1% Preparing: 4.2% Preparing: 4.3% Preparing: 4.4% Preparing: 4.5% Preparing: 4.6% Preparing: 4.7% Preparing: 4.8% Preparing: 4.9% Preparing: 5.0% Preparing: 5.1% Preparing: 5.2% Preparing: 5.3% Preparing: 7.5% Preparing: 7.6% Preparing: 7.7% Preparing: 7.8% Preparing: 7.9% Preparing: 8.0% Preparing: 8.1% Preparing: 8.2% Preparing: 8.3% Preparing: 8.4% Preparing: 8.5% Preparing: 8.6% Preparing: 8.7% Preparing: 8.8% Preparing: 8.9% Preparing: 9.0% Preparing: 9.1% Preparing: 9.2% Preparing: 9.3% Preparing: 9.4% Preparing: 9.5% Preparing: 9.6% Preparing: 9.7% Preparing: 9.8% Preparing: 9.9% Preparing: 10.0% Preparing: 10.1% Preparing: 10.2% Preparing: 10.3% Preparing: 10.4% Preparing: 10.5% Preparing: 10.6% Preparing: 10.7% Preparing: 11.1% Preparing: 32.3% Preparing: 32.9% Preparing: 37.5% Preparing: 37.6% Preparing: 42.3% Preparing: 42.4% Preparing: 47.1% Preparing: 51.9% Preparing: 100.0% An error occurred preparing the update.
