Cannot login to Casper Admin after migration to casper 9
  • August 30, 2013
  • 11 replies
  • 7 views
i can login JSS with web no problem but not with casper Admin or any other apps...
error :
the server located at
https://.....
did not respond with valid information...
my jss address is fine... my privileges are fine... everything works fine with jss... but with the casper admin app version 9 can't access...
ImAMacGuy
Forum|alt.badge.img+23
  • August 30, 2013
that's the same problem we had, I had to roll back to 8.71.
open a ticket with jamf.
  • August 30, 2013
that's what i did too...
  • August 30, 2013
This initially happened to us as well but was fine after a restart.
  • August 30, 2013
unfortunately its the error i have after multiple restart or even restoring my server and doing upgrade a second time...
Brad_G
  • September 3, 2013
I had the issue with an LDAP ID but if I used a local ID within the JSS it would connect.
ImAMacGuy
  • September 3, 2013
@Brad_G: interesting. But I just tried it on my dev 9.0.1 box and I couldn't get in with a local or ldap account.
  • September 3, 2013
Me neither... could not get in with local or LDAP account... but JSS works fine....
  • September 3, 2013
Could this be related to privileges? If a user is assigned to a site they cannot access Casper Admin.
  • September 3, 2013
hi... i have no sites created...
retried with version 9.01... same thing... something must be wrong... start to drive me crazy...
  • October 4, 2013
I'm having the same problem on my test box. Any ideas?
  • October 27, 2014
I had similar issues, and fixed it by using a different local account on my boot media. When connecting with the new account, I was prompted to re-enter the server name and the connection was successful.
