No offense but, if you don't have a developer account to access the 10.11 beta builds, no-one here can really tell you much about any betas. Actually even if you had an account, no-one here can talk about it (on JAMFNation) due to the NDA they have signed with Apple. This is not the place for such discussions.
They might be able to just very generally tell you if they have seen some good fixes in the latest beta release, but that would be about the limit of it without actually breaking their NDA.
@mm2270 is right. Not worth the hassle for anyone in trouble over. However, usually there are Mac focused sites that talk about beta releases: http://www.macrumors.com/roundup/os-x-10-11-1/
Dig through the articles and discussions there. Maybe you'll find something. I haven't looked. But I've seen people talk about their experiences on beta releases before so it might be worth a look.
Might also be worth $100/yr to just get a dev account too so you could test it on your own.
Public beta should be available soon.
Our Web Team have the iOS developer account. We will sign up for the OS X developer account.
Thank you,
I thought the Apple Developer program now included both iOS and OS X developer access? Have them check to see if they have that access; maybe your company can get one company Developer account for your teams so you can get that access.
@emilykausalik You're correct, one account to rule them all.
