If you deploy Adobe Creative Cloud, you will want to take a look at the following user voice page and up vote and comment:
https://creativecloud.uservoice.com/forums/923263-apps-section-app-catalog-install-updates/suggestions/42883680-support-universal-macos-installer-that-works-on-bo
The gist is that Adobe has created new installers that are hardware specific: they either run on Intel or Apple Silicon, but not both! This has created double the work for admins to deploy Adobe apps by having installers.
