Carbon Black Response (EDR) Network Filter
  • March 31, 2021
  • 6 replies
  • 115 views
Hey guys... anyone know how to create a config profile for the Carbon Black Response network filter on Big Sur???
  • March 31, 2021
Instructions from CBC
VMware, Inc.
Carbon Black Cloud Sensor MDM-instructions.txt (August 18, 2020)
I. MDM Kext Approval Configuration Approving Carbon Black KEXTs via MDM can be accomplished via a KEXT Approval Configuration Payload. The recommended way to deliver this configuration is through the provided MDM-KEXT-approval.mobileconfig file. This mobileconfig provides the necessary configuration which can be uploaded to your organization's MDM-compatible software deployment tool. To construct this configuration manually, you must specify the Apple Team ID and KEXT bundle in your configuration profile Apple Team ID: 7AGZNQ2S2T KEXT Bundle ID: com.carbonblack.defense.kext
KEXT post install approval on Big Sur (Introduced in Big Sur Beta 10): In order to allow the KEXT to load on MacOS Big Sur, the OS either requires a local action from an admin to approve the KEXT after install, or a customized reboot command from your MDM, to rebuild the Kernel Cache. Please see Apple documentation here: https://developer.apple.com/documentation/devicemanagement/restartdevicecommand/command The recommended way to deliver this configuration is through the provided MDM-KEXT-reboot-command.xml file. This XML file should be uploaded as a Custom Command and sent to endpoints after KEXT install. Note that this will reboot the target machine without warning, and that this distribution method is a temporary workflow until MDM providers update their reboot protocols to support RebuildKernelCache.
II. MDM System Extension Approval Configuration Approving Carbon Black System Extensions via MDM can be accomplished via a System Extension Approval Configuration Payload. The provided MDM-SYSEXT-approval-mobileconfig-sample.txt provides a snippet of an example mobileconfig that correctly implements this profile. To construct the correct configuration, you must specify the Apple Team ID and System Extension bundle in your configuration profile System Extension Types: Allowed System Extensions Apple Team ID: 7AGZNQ2S2T System Extension Bundle ID: com.vmware.carbonblack.cloud.se-agent.extension
III. MDM Network Extension Web Content Filter Configuration Granting the Network Extension component of the Carbon Black System Extension access to filter network content can be accomplished via a Web Content Filter Payload. The recommended way to deliver this configuration is through the provided MDM-SYSEXT-network-extension-approval.mobileconfig file. This mobileconfig provides the necessary configuration which can be uploaded to your organization's MDM-compatible software deployment tool after it is signed by your organization's signing tool. These instructions were created using Apple documentation and ProfileCreator (found here: https://github.com/ProfileCreator/ProfileCreator) When exporting this profile, the profile should be signed to enable distribution via MDM. To construct this configuration manually: The fields should be completed exactly as follows. Please copy and paste for accuracy. In the General payload: Payload Scope should be set to: System In the Web Content Filter payload: Filter Type should be set to: Plug-In Plug-In Bundle ID: com.vmware.carbonblack.cloud.se-agent Check Enable Socket Filtering Filter Data Provider System Extension Bundle ID (macOS): com.vmware.carbonblack.cloud.se-agent.extension Filter Data Provider Designated Requirement (macOS): identifier "com.vmware.carbonblack.cloud.se-agent.extension" and anchor apple generic and certificate 1[field.1.2.840.113635.100.6.2.6] / exists / and certificate leaf[field.1.2.840.113635.100.6.1.13] / exists / and certificate leaf[subject.OU] = "7AGZNQ2S2T" Check Enable Packet Filtering (macOS) Filter Packet Provider System Extension Bundle ID (macOS): com.vmware.carbonblack.cloud.se-agent.extension Filter Packet Provider Designated Requirement (macOS): identifier "com.vmware.carbonblack.cloud.se-agent.extension" and anchor apple generic and certificate 1[field.1.2.840.113635.100.6.2.6] / exists / and certificate leaf[field.1.2.840.113635.100.6.1.13] / exists / and certificate leaf[subject.OU] = "7AGZNQ2S2T"
IV. MDM Privacy Preferences Payload Configuration Granting an application full disk access via MDM can be accomplished via a Privacy Preferences Payload. The recommended way to deliver this configuration is through the provided MDM-privacy-config.mobileconfig file. This mobileconfig provides the necessary configuration which can be uploaded to your organization's MDM-compatible software deployment tool. To construct this configuration manually, we must add four identifiers into this Privacy payload. The fields should be completed exactly as follows. Please copy and paste for accuracy. 1) Identifier: com.vmware.carbonblack.cloud.daemon Identifier Type should be set to: Bundle ID Code Requirement: identifier "com.vmware.carbonblack.cloud.daemon" and anchor apple generic and certificate 1[field.1.2.840.113635.100.6.2.6] / exists / and certificate leaf[field.1.2.840.113635.100.6.1.13] / exists / and certificate leaf[subject.OU] = "7AGZNQ2S2T" App or Service should be set to: SystemPolicyAllFiles Access should be set to: Allow 2) Identifier: com.vmware.carbonblack.cloud.se-agent.extension Identifier Type should be set to: Bundle ID Code Requirement: identifier "com.vmware.carbonblack.cloud.se-agent.extension" and anchor apple generic and certificate 1[field.1.2.840.113635.100.6.2.6] / exists / and certificate leaf[field.1.2.840.113635.100.6.1.13] / exists / and certificate leaf[subject.OU] = "7AGZNQ2S2T App or Service should be set to: SystemPolicyAllFiles Access should be set to: Allow 3) Identifier: com.vmware.carbonblack.cloud.osqueryi Identifier Type should be set to: Bundle ID Code Requirement: identifier "com.vmware.carbonblack.cloud.osqueryi" and anchor apple generic and certificate 1[field.1.2.840.113635.100.6.2.6] / exists / and certificate leaf[field.1.2.840.113635.100.6.1.13] / exists / and certificate leaf[subject.OU] = "7AGZNQ2S2T" App or Service should be set to: SystemPolicyAllFiles Access should be set to: Allow 4) Identifier: com.vmware.carbonblack.cloud.uninstall Identifier Type should be set to: Bundle ID Code Requirement: identifier "com.vmware.carbonblack.cloud.uninstall" and anchor apple generic and certificate 1[field.1.2.840.113635.100.6.2.6] / exists / and certificate leaf[field.1.2.840.113635.100.6.1.13] / exists / and certificate leaf[subject.OU] = "7AGZNQ2S2T" App or Service should be set to: SystemPolicyAllFiles Access should be set to: Allow 5) Identifier: com.vmware.carbonblack.cloud.uninstallerui Identifier Type should be set to: Bundle ID Code Requirement: identifier "com.vmware.carbonblack.cloud.uninstallerui" and anchor apple generic and certificate 1[field.1.2.840.113635.100.6.2.6] / exists / and certificate leaf[field.1.2.840.113635.100.6.1.13] / exists / and certificate leaf[subject.OU] = "7AGZNQ2S2T" App or Service should be set to: SystemPolicyAllFiles Access should be set to: Allow
  • March 31, 2021
@Phil.James thanks! Good lord that's a lotta stuff, but unfortunately we're not using CB Cloud, but using CB Response
  • April 29, 2021
Has anyone been able to create a working config profile to eliminate this pop-up? I built Config profiles for MDM Network Extension Web Content Filter Configuration using ProfileCreator and I still have the popup on devices that have the config profile installed prior to installing VMWare Carbon Black.
Been trying to fix for the last 3 days!
  • May 14, 2021
I got this from carbon black and it worked for me:
Carbon Black EDR: Granting macOS Sensor Access on
macOS 11.0+ Big Sur
Supported Product: Carbon Black EDR
Supported Sensor Version: 7.0+
Supported macOS Version: 11.0+
Sections in this document:
● Approving the System Extension and Network Filtering Component for macOS
Sensor Version 7.0+ on macOS Big Sur
○ Manually Approving the System Extension and Network Filtering
○ Approving the System Extension via MDM
○ Approving Network Filtering via MDM
● Granting the Sensor Full Disk Access
○ Manually Granting the Sensor Full Disk Access
○ Granting the Sensor Full Disk Access via MDM
As part of the transition to system extensions in macOS 11.0 and above, users need to approve
the new system extension as well as network filtering and allow Full Disk Access. While this
sounds sinister, it’s actually a similar process to when an iOS app requests access to the
camera, for example. This is similar to kernel extension approval which was added in macOS
10.13, and does not replace that process for running our EDR sensor on macOS versions prior
to 11.0.
In order to be completely effective, it is imperative that the Carbon Black EDR macOS sensor
gets approval for the system extension, network filtering, and Full Disk Access. This can be
done manually on each endpoint or for quicker and more consistent endpoint management,
these settings can be managed across your organization through the creation and deployment
of a mobile device management (MDM) profile. Read on to learn more about running the
macOS sensor unimpeded on endpoints.
Approving the System Extension and Network Filtering Component for macOS Sensor
Manually Approving the System Extension and Network Filtering:
VMware Carbon Black recommends submitting the applicable CB EDR System Extension IDs
for approval by MDM before install or upgrade to macOS 11 Big Sur. However, if the System
Extension is not pre-approved by MDM, you can approve System Extensions locally upon
upgrading the OS.
1. On an endpoint running macOS 11 Big Sur, after installing/upgrading the sensor on
the endpoint, navigate to the General tab in the Security & Privacy pane in System
Preferences.
2. Authenticate as an administrator and click the Allow button next to the “System
software from application “es-loader” was blocked from loading” message.
3. Click the Allow button on the “‘es-loader’ Would Like to Filter Network Content”
pop-up.
The installer will finish running and load.
Approving the System Extension via MDM:
Note:
https://github.com/ProfileCreator/ProfileCreator ). Field names, values, and functionality may
vary depending on the MDM framework or sensor version used.
Approving Carbon Black System Extensions via MDM is the recommended method. The
following are the manual steps to create the correct mobileconfig in your MDM. You can
accomplish this by specifying the Apple Team ID and System Extension bundle Identifier in your
Allowed System Extension configuration profile:
System Extension Bundle ID: com.carbonblack.es-loader.es-extension
Your configuration in Workspace One should be similar to the following image:
In JAMF, your configuration should look something like this:
Approving Network Filtering via MDM:
Approving the Carbon Black Network Extension Component of the System Extension via MDM
is the recommended method. You can grant the System Extension the ability to Filter Network
Content via a Web Content Filter configuration profile.
Note:
After creating this profile, the profile should be signed to enable distribution via MDM.
Plug-In Bundle ID: com.carbonblack.es-loader
identifier " com.carbonblack.es-loader.es-extension " and
exists
exists
Payload should look like this at the end:
Manually Granting the Sensor Full Disk Access:
In order for the Carbon Black EDR macOS sensor to operate at full functionality on an endpoint
running macOS 11 Big Sur the system extension must have Full Disk Access on the endpoint.
To enable Full Disk Access manually, begin by navigating to the Security & Privacy System
Preferences section and selecting the Privacy tab.
Once authenticated as an Administrator, scroll down to Full Disk Access section.
Approve the application named “ es-extension ”, if present.
Granting the Sensor Full Disk Access via MDM:
The following are the manual steps to create and distribute the necessary Privacy Preference
payload in your MDM.
Note:
Field names, values, and functionality may vary depending on the MDM framework or sensor
version used.
Granting an application full disk access is accomplished via a Privacy Preferences payload. We
are going to add 2 identifiers into this Privacy payload.
1)
Identifier: com.carbonblack.CbOsxSensorService
Identifier Type : Bundle ID
Code Requirement:
identifier "com.carbonblack.CbOsxSensorService" and anchor
App or Service : SystemPolicyAllFiles
Access : Allow
Press the plus (‘+’) button to append an additional identifier.
2)
Identifier: com.carbonblack.es-loader.es-extension
Code Requirement:
identifier " com.carbonblack.es-loader.es-extension " and anchor
Post Tags: macOS, 10.14, 10.15, 11, Big Sur, MDM, mobile device management, full disk
access, macOS sensor, carbon black cloud, jamf, Workspace ONE UEM, PPPC
  • June 7, 2021
I still get the popup "com.carbonblack.es-loader" to filter Network Content. I attached my Config Profile. Can anyone assist in getting this resolved for me?
  • June 7, 2021
I have the following configuration and do not see the Network Filter popup. The app itself that we have in our environment is "VMWare Carbon Black EDR".
