API 409 error
  • August 21, 2020
  • 9 replies
  • 93 views
rstasel
Hi All,
I'm at wits end with an API job that SHOULD set an extension attribute, but instead just comes back with a 409 error and no good info WHY.
apiUser="user"
apiPass="pass"
jssURL="https://jss.example.com:8443"
ea_number="91"
serial=$(system_profiler SPHardwareDataType | grep 'Serial Number (system)' | awk '{print $NF}')
name=$(curl -s "https://inventory.example.com/serial/$serial" | grep -A1 -o "Device name:" | tail -n1 | sed 's/^[ 	]*//;s/[ 	]*$//' | cut -d" " -f1)
if [ ! $name ]; then
        name="Undefined"
# Create xml
echo "<computer><extension_attributes><extension_attribute><id>$ea_number</id><value>$name</value></extension_attribute></extension_attributes></computer>" | xmllint --format - > /private/tmp/ea.xml
## Upload the xml file
curl -vvvfku "${apiUser}":"${apiPass}" "${jssURL}/JSSResource/computers/serialnumber/${serial}/subset/extensionattributes" -H "Content-Type: text/xml" -T /private/tmp/ea.xml -X PUT
And all I get back from the API is "the requested URL returned error: 409". The full PUT url looks like:
/JSSResource/computers/serialnumber/C1MQ41xxxxxx/subset/extensionattributes
(obviously the serial is obfuscated). I see nothing wrong. the account being used has update/read for computers, computer extension attributes, and read for sites. I've tried just giving it all rights, same result.
JSS is on 10.22.1.
Anyone see what I'm doing wrong? Oh, the xml the script generates looks like:
<?xml version="1.0"?>
<computer>
      <id>91</id>
      <value>Undefined</value>
</computer>
I've tried with and without the pass through xmllint and the results are the same. I've also confirmed there's not some random phantom duplicate device in our JSS with the same serial (doing an API call with same api account, just polling for computer ID based on serial, returns one result).
Best answer by rstasel
Figured it out. So apparently when I'd tried other permissions, something else was broken in the script, that also resulted in a 409 error.
Stepped back to just manually crafting a PUT and was getting a "Not authorized for user PUT". Turns out, even to update a computer extension attribute, you need user access: https://www.jamf.com/jamf-nation/discussions/17846/9-81-issue-with-api-update
Specifically, since I just tested this, you need "UPDATE" permission to Users, as well as read. This makes... zero sense, but works.
rstasel
  • August 21, 2020
Looking at this: https://www.jamf.com/developers/apis/classic/reference/#/computers/findComputersBySerialNumberSubset
Makes me think maybe you can't PUT based on serial number? So I would need to get the ID, then do the put?
Going to test that.
rstasel
  • August 21, 2020
same results.
rstasel
  • August 21, 2020
Forum|alt.badge.img+31
  • August 22, 2020
This is probably due to the fact that you can have EAs from the User objects so it is a dependency. That is my guess
rstasel
  • August 24, 2020
Nope....
Forum|alt.badge.img+20
  • Employee
  • August 24, 2020
Documentation on the privileges required to interact with a given endpoint/resource can be found here. Updates to the user and location information also updates any user objects associated with that device, hence why the additional privilege is necessary in this case. The API does not differentiate between the contents of the request body to know whether you're including information that would require those privileges, therefore all calls to that resource/operation combo require the same privileges.
rstasel
  • August 24, 2020
Sure, but I'm not updating user or location... I'm updating a computer extension attribute, which according to the docs, JUST needs "/computerextensionattributes/id/{id} PUT Update - Extension Attributes"
I also gave Read since I also wanted to read back, as well as read for computers.
I don't see anything that indicates I should be required to have User update rights for writing to a computer EA...
rstasel
  • August 24, 2020
Ah, so it's really this line, not the one I posted (that line is regarding changing the actual EA, not changing the value stored in the EA.
/computers/id/{id} PUT
Update - Computers
Update - Users
Still weird that it's (seemingly) doing a authorization check before checking what I'm actually trying to update.
rstasel
  • August 24, 2020
Though, regardless, I was getting a 409 when I lacked "Users" permission. Seems like it should be returning a 401 instead.
