deactivate guest mode on shared iPads
  • August 25, 2020
  • 6 replies
  • 56 views
Hi, since iOS 13.4 there is the option to log in as a guest user. We don't want our users to log in as guests.
Is there a way to disable this option? We haven't found anything in the PreStage Enrollments or Configuration Profiles.
  • August 25, 2020
Apple refers to it as a "Temporary Session" in documentation. You can disable it with a Restrictions profile:
Restrictions -> Functionality -> Shared iPad (device) Temporary Session -> Restrict
  • August 25, 2020
Thanks for the fast help! Haven't seen this before :)
  • September 15, 2020
Hi, I can't find this option in current Jamf. Hast it moved?
I just checked in 10.23 and it still there.
  • October 12, 2020
In my case, I want only the Guest account to show and not the managed apple id login. We plan to do these for checkout or KIOSK iPads so that the data wipes at logout for the next user. I have not found a solution for this. Guest account shows in the lower right hand corner and it would be great if it appeared in the center of the screen, to make it obvious. Can a restriction be placed to restrict Apple ID login? Spitballing here....
We are higher education and have not implemented managed apple ids, other than some test individuals. Migrations to that will be problematic due to users who already have personal Apple IDs set up with there institutional email addresses.
  • December 13, 2022
Did you ever get any kind of response/solution to this?  I'm dealing with the same situation.
