Hi All,
I have tried to set a custom screen saver from using a script from a previous post. lHere. but have had no luck.
I had added the script as a post install on the package to drop the screen saver on a Mojave & Catalina machine
The custom Image appears in /Library/Screen saver/ but does not set for the current user,
#!/bin/zsh
# Get user logged into console and put into variable "user"
user=`ls -l /dev/console | cut -d " " -f 4`
osMajor=$(sw_vers -productVersion | awk -F"." '{print $2}')
osMinor=$(sw_vers -productVersion | awk -F"." '{print $3}')
sudo -u $user defaults -currentHost write com.apple.screensaver CleanExit -string "YES"
sudo -u $user defaults -currentHost write com.apple.screensaver PrefsVersion -int 100
sudo -u $user defaults -currentHost write com.apple.screensaver showClock -string "NO"
sudo -u $user defaults -currentHost write com.apple.screensaver idleTime -int 120
if [[ $osMajor -eq 14 && $osMinor -ge 2 ]] || [[ $osMajor -ge 15 ]] ; then
sudo -u $user defaults -currentHost write com.apple.screensaver moduleDict -dict moduleName -string "iLifeSlideshows" path -string "/System/Library/Frameworks/ScreenSaver.framework/PlugIns/iLifeSlideshows.appex" type -int 0
sudo -u $user defaults -currentHost write com.apple.screensaver moduleDict -dict moduleName -string "iLifeSlideshows" path -string "/System/Library/Frameworks/ScreenSaver.framework/Resources/iLifeSlideshows.saver" type -int 0
sudo -u $user defaults -currentHost write com.apple.screensaver tokenRemovalAction -int 0
sudo -u $user defaults -currentHost write com.apple.ScreenSaverPhotoChooser LastViewedPhotoPath -string ""
sudo -u $user defaults -currentHost write com.apple.ScreenSaverPhotoChooser SelectedFolderPath -string "/Library/Screen Savers/Default Collections/5 - Test"
sudo -u $user defaults -currentHost write com.apple.ScreenSaverPhotoChooser SelectedSource -int 3
sudo -u $user defaults -currentHost write com.apple.ScreenSaver.iLifeSlideShows styleKey -string "Brooklyn"
killall -hup cfprefsd
Any help would be great.
