One Approved System Extensions Profile Or Multiple?
  • April 28, 2021
  • 44 views
john_sherrod
Wondering what you all do when you need to whitelist multiple system extensions. So far I've only ever had a single configuration profile for white listing all of my needed system extensions. But sometimes only a small number of my users need a particular system extension approved so it doesn't seem like it makes sense to white list it for the entire fleet. How do you all handle these scenarios?
  • April 28, 2021
Separate profiles for separate extensions. It makes it a lot easier when its time to revoke one. You don't have to redistribute to the whole fleet.
john_sherrod
  • April 28, 2021
That's kinda what I was thinking. Thanks! Would be curious to hear from others as well how they handle it.
