API Script for Mass Action MobileDevice Restart
  • May 4, 2021
  • 34 views
I am familiar with the mobiledevicecommand with the RestartDevice payload which is great for resetting one or several IDs, but I'd like to have a SmartDeviceGroup where I can apply the Action to all members to RestartDevice using the API.
So far I am not even sure if the API supports this logic.
Does anyone have an example of how to do this?
1 reply
ktrojano
Forum|alt.badge.img+21
  • February 22, 2022
I'm looking for the same thing for Apple TVs and came across this: https://community.jamf.com/t5/jamf-pro/api-script-for-ipad-restart/td-p/176439
I'm going to give it a try.
