I have some student ipads that are not showing Apple Classroom, Does anyone have any idea why this would happen?
Page 1 / 1
Ad-hoc or managed classes?
managed
Do the iPads have an EDU profile installed? When you look under Inventory>Profiles you should see an EDU one. The other thing to check is in Jamf under the Users tab. Do a search for the user and check if they have a General,Roster, and Device listed in one.
