Adjust web session timeout
  • October 1, 2020
  • 67 views
Is there any way to adjust the web session timeout of Jamf Cloud without subscribing to Premium Cloud?
Forum|alt.badge.img+31
  • October 1, 2020
If you are using SSO you can, as for normal local accounts not sure
  • November 11, 2022
Not really an exact answer to your question, and also mostly posting this for awareness for people still looking for an answer, since this thread is pretty old.  https://github.com/fveja/JSSCaffeinate
  • May 3, 2023
Thanks for this link. Installed Greasemonkey, imported the modified script and it works like a charm. No session time-outs in the Jamf Cloud anymore :-).
