Hi there,
some of our computers have problems with the Cisco AnyConnect Client - as soon as it is installed, the CPU load is at 100% - it is noticeable that a check with the terminal command "systemextensionsctl list" shows that the Cisco extension is not enabled - but on most devices it is. How can I enable the extension again?
OS: Big Sur 11.3.1 or 11.4, same results
EtreCheck has spit out this:
Kernel Extensions:
/Library/Application Support/Cisco/AnyConnect Secure Mobility Client
[Not Loaded] acsock.kext - com.cisco.kext.acsock (4.10.01 - SDK 10.14)
I'm attaching my deployed config profile in images to be on the safe side.
There is 4.10.01075 update
Same with the new version... VPN disconnects also...
