Hi there
We have a issue, Active Directory Users can't access any network share.
if I log in as a local user and connect to a network share with the AD User it works properly, so it is not a permission problem.
After a reinstall of macOS 10.14.6 it works again. but a few days later it stops working again.
Does anybody had this issue before?
any help is appreciated
Security Update 10.14.6 2021-004 breaks kerberos, see https://www.jamf.com/jamf-nation/discussions/39042/kerberos-sso-hanging-with-mojave-security-update-2021-004 for a workaround.
great, you just saved my day! been on this problem since 4 days now!
everything is working again.
My biggest and sincere thanks goes to you.
thanks
Thanks, but I think the biggest thanks should go to the people that came up with the workaround, not to me.
Sorry me again, now we have the problem that Google Drive Sync Client is not working anymore.
It wants a new auth, but still not working.. any workaround for that?
regards
