Change Mac hostname to match computer name
  • June 22, 2021
  • 4 replies
  • 66 views
Yo..
We have many Mac's whose hostname doesn't match their computer name.
Is there any easy script we could use that will 1...get the computer name and then 2...use scutil to set the hostname to match the computer name?
pkleiber
  • June 24, 2021
Something like this maybe:
## Get ComputerName
HOST=$(scutil --get ComputerName)
## Set HostName and LocalHostname
scutil --set HostName "$HOST"
scutil --set LocalHostName "$HOST"
emanueldiaz_09
## Get ComputerName
I did what this @pkleiber has.
You can also create a smart group using an extension attribute.
What I did for the script in the extension attribute is add this script and set Input Type to String:
#!/bin/sh ##set variables to check computername and hostname on the device HostName=$(scutil --get HostName) CompName=$(scutil --get ComputerName) ##function to check if hostname is set if [[ "$HostName" != "$CompName" ]]; then #If hostname does not match computer name echo "<result>Not Set</result>" else #If host name is = to computer name echo "<result>Set</result>" fi
 This script will output values "Set" is hostname matches computer name or "Not Set" if it doesn't match.
When you have your devices that do not match. You can target a policy with this script to change the hostname to the computer name:
#!/bin/sh ##Set variable to get computer name CompName=$(scutil --get ComputerName) ##set Hostname to Computername scutil --set HostName "$CompName" ##Flush DNS on device (optional, uncomment if you want to flushDNS) ##dscacheutil -flushcache ##Updates user passwords with preboot (Optional) ##diskutil apfs updatePreboot / ##sends updated device information to Jamf jamf recon
What criteria did you use to create a smart group for them not to be "Not set" for this to apply to
emanueldiaz_09
I use the first code above as an extension attribute. For the criteria you can use what's in the <result> tag. Either:
Not Set
or
Set
Depending on whether you want to grab devices that have hostname set or devices that do not. I used Not Set so I can see the devices that do not have their hostname matching Computer name then use the second script in a policy to target those computers.
