Self-Service on iOS7 opens in Safari?
  • September 18, 2013
  • 11 replies
  • 52 views
Having an issue on JSS 9.1 where the new Self-Service opens in Safari (not self-contained).
Fresh iOS7
Fresh enrollment
Issue occurs
Existing Enrollment
iOS7 OTA update
new Self-service downloaded via inventory update
Issue occurs
Existing Enrollment
iOS6.1.3
new Self-service downloaded via Inventory update
Issue does NOT occur.
Best answer by jake11
Hi Everyone
After upgrading to 9.1 and 8.72, as discussed above, the web clip deployed to iOS7 devices is no longer a full screen web clip.
The ability to use URL handlers in full screen web clips is no longer available in iOS7. This means Self Service would no longer be able to deploy ebooks or unmanaged apps if it was still full screen. Because of this, we made the decision to use a non-full screen web clip on iOS 7 for Self Service.
We have a radar open about the use of URL handlers in iOS7 with a full screen web clip. RADARĀ 14848305.
Thank you for all the feedback. We are investigating other technologies to make this a better experience for the end users moving forward.
  • September 19, 2013
same for me, i hope it's bug and will be fixed
Response I got on Twitter:
From @JAMFSupport:
"The web clip is no longer full screen in 9.1. Due to security changes in iOS 7, it opens up in Safari"
but i'm able to make full screen web clip via configuration profile and it opens not in safari. am i missing something?
Well, this sort of makes since since it was really always a web page, just that before it was able to take advantage of the Webkit engine and the webclip functionality to appear as a full screen app. I guess Apple is doing away with that function, for security reasons as noted.
If you ask me, its time for JAMF to consider making a full iOS app to handle Self Service. I fully understand the advantage of webclips in that no actual app bundle needs to be downloaded, as well as the fact that webclips can be locked down to the profile, and thus not easily deleted like apps can. But given this change, its almost like the magic curtain is being drawn back, revealing to end users what it actually is. Could be a non-issue, but could also lead to some confusion.
Besides, it seems to me the user community has been looking for more functionality out of the Self Service "app" under iOS, and a full app bundle could be the answer to get there. Webclips can only do so much.
So Full screen web clips still work. I think we need someone to look at this as a bug, then.
have already submitted it to the support.
got answer that it's a bug and task id is D-005301
This is what I got:
A little update on this issue here. This is actually not a defect. Under iOS 7 we can no longer open the app store from full-screen web clip links. We're not sure if this is intended or a bug, but we've reached out to Apple regarding the issue.
That's the latest I have, hopefully we come up with a resolution for this soon, but for now that is the way it works, or doesn't work based on whether you're a glass half empty or half full type of person.
Hopefully that clears things up!
Thanks,
Zach Mercer
JAMF Support
bentoms
Forum|alt.badge.img+35
Hmmm.. AirWatch's app catalog web clip is full screen for me on iOS7.
I've made a full screen webclip with the same URL that original self service webclip had. pushed it into device, opened apps tab and successfully installed an AppStore app.
  • Employee
Hi Everyone
Forum|alt.badge.img+15
  • September 20, 2013
Thanks Jake.
