Suppress Teamviewer opening after installation
  • October 29, 2020
  • 6 replies
  • 110 views
mucgyver
Dear all.
Is anyone of you aware of a way how to prevent
the auto-starting of Teamviewer (and with that, the basic setup assistant) after the installation?
I have seen that there are quite a few Launch agents and Launch Daemons included in the installer package, but I don't really know how to manipulate the portions in there to just block the auto start after installation.
Any idea? Thanks a million.
Cheers
Chris
Best answer by mucgyver
@Chris , whoah, that was a quick solution. Splendid. Thanks!
  • October 29, 2020
mucgyver
  • October 29, 2020
mucgyver
  • October 29, 2020
Jason33
  • November 23, 2020
Is there anyway to preconfigure the unattended access window? I've built a .dmg for the installer and set FUT and FEU, but on a new install the popup is launched upon first run of TeamViewer.
mucgyver
  • November 25, 2020
@Jason33 I think there is simply no way/no sense to bypass this, as you cannot pre-allow things like screen recording, by OS design (privacy and user consent).
  • February 13, 2024
Hey @mucgyver,
i have also added the script to our TeamViewer host installation. However, the window still appears - have I missed something?
