Zoom 5.4.1 (58698.1027) not showing in patch management
  • October 29, 2020
  • 4 replies
  • 25 views
5.4.1 (58698.1027) was released yesterday (28 Oct 20).
Patch Management for our JAMF instance doesn't show this. It only shows the 5.4.0 update which was released on the 26th. It says that's the latest version. That's wrong. 5.4.1 is the latest version.
5.4.1 is installed on 60 machines and right now those are being reported as Unknown versions.
What's up with that? How does JAMF update their patch management for latest versions?
Best answer by robinsonjo
Hello @dugnl and @techjason !
The Zoom Software Title has been updated, apologies for the delay.
Jon
  • October 29, 2020
@dugnl Patch Management usually takes at least a day to catch up. You will notice that this happens with all programs. I see this every month with Microsoft Office apps. It will most likely be up to date by tomorrow.
I think the reason that it is not immediately updated is that some times vendors will pull an update within the first day because of issues.
  • Employee
  • October 29, 2020
Jon
  • October 29, 2020
I noticed this too! Thanks for getting that sorted!
Kast
  • July 10, 2023
Jon
Now is happening with Firefox: https://ftp.mozilla.org/pub/firefox/releases/102.13.0esr/mac/en-GB/ released on July the 4th. Is is the same issue?
